Eric's E92 build
Erichale77
827
447
Clearwater, FL
07 E92 coupe
Finally getting car back together after a 2 year engine build. Had a lot of extensive work done by VAC on motor which includes closed deck block, stage 4 head with plugged ports and larger exhaust valves (more modifications than standard stage 3 head), 268 high lift Schrick cams with Ferrera valve train and new vanos spools.
DSC00092.JPG DSC00089.JPG IMG_0971.jpeg IMG_1031.JPG DSC00220.JPG 20170925_130308.jpg 11091508_755932117861019_2656675318452129374_n.jpg 11165256_755932131194351_6230048258088716013_n.jpg 11295582_755932151194349_4232105358761914090_n.jpg IMG_3693.JPG 20170816_134151.jpg Motor.jpg
Erichale77
827
447
Clearwater, FL
07 E92 coupe
I went with Arrow rods, CP pistons 10.5-1 with coated domes and skirts and hardened wrist pins, VAC coated main and rod bearings, ATi balancer and ARP main, rod and head studs. Oil pan has welded windage tray and custom oil drain fittings,
Reactions: Abacus38
Erichale77
827
447
Clearwater, FL
07 E92 coupe
FabFactory in Tampa is doing all the custom work. I'm soo lucky to have these guys doing my build. THE BEST THERE IS! I have custom FabFactory manifold with port injection, running Injector Dynamics ID1300 injectors, Vargas double barrel shotgun, Fuel-it stage 3 lpfp in tank with custom lines and E85 sensor.
11108976_762216270565937_6604848934093802563_n.jpg N54under.jpg double barrel.jpg
Reactions: Abacus38
I think they say if you go too far north of 700-800 you need PI or some kind of supplemental fuel. I can't wait to see this engine scream past 1k!
Erichale77
827
447
Clearwater, FL
07 E92 coupe
Properly tuning these engines anywhere past 800HP gets very tricky. Not all means of logging are effective at high rpm and big HP numbers. Fueling is only one issue to deal with.
tommyhondros
62
14
e92 335xi coupe
Jesus dude this might be the best build I’ve seen so far. One question did you raise the torque converter on the tranny? If so to what rpm
Erichale77
827
447
Clearwater, FL
07 E92 coupe
It had changes made to the internals (stator fins I think) but I need to find out exactly what. I honestly forgot it's been so long.
