EKP fuel pump controller not working
dfbpurcell
EKP module isn't working
Code CDA6: Message (status, electric fuel pump, 0x335) incorrect, receiver DME, transmitter EKP.
Tried replacing F40 fuse and replacing EKP module.
Visual inspection of pins and cables looks good.
Anyone run in to this problem before?
rev210
244
335i - 08 Coupe .
Two cooked EKPs in a row more likely than anything else?
Well perhaps ? If the first one died there was likely a reason ,which unless you have addressed it will increase the odds
You did recode the new EKP right ? There are different models of EKP for different chassis too, I think there are some voltage differences ? See if you can get the diagnostics to talk to/read the EKP , guessing it was fine when you coded it?
Shiftergarage96
Did u sort out this issue?
