E82 N55 dct code 29E0 reduced power
Jan 27, 2018
13
E82 135 DCT
Good day
Just want to find out if anyone has had this code 29E0 (Charge - air temp sensor Short circuit to B+ )
We have tested the Earth to Tmap and its fine.
The only thing is that my car stood for like almost a year without it starting or driving. Jb4 harness connected.
Car is in reduced power mode.
ap485
74
55
Houston, TX
2011 BMW E92 335i
Check if the IAT reading is off compare to ambient temperature at cold start. Then, watch the IAT while your cruising. If the reading jumps abruptly up or down and the car gets a engine malfunction light, most likely you have a bad TMAP sensor.
Chrysheight
20
San Jose, CA
2011 E93--N55 6MT
I'm getting this code and reduced power after JB4 install. Triple checked the connections and everything is fine. I have no idea what is going on.
Jan 27, 2018
13
E82 135 DCT
Hi all. Ive done all the above and still same code. Did the earth to chassis from tmap. Replaced sensor. Removed JB4 and checked harness. Also earth to ECU is fine. Gana dlash the cars ecu and see.
