E60 535i charge pipe
Kenjermen
78
75
N las vegas NV
I am looking to do a couple mods to my 535i. I was wondering if the 335i charge pipe will fit? I plan on running a BOV and not the diverter valves. I have my old wagner intercooler from my 335i that I plan on fitting as well.
Rickz96
I run the Burger Tuning BMS 7.5” high density e chassis race FMIC. It is spec’d for 335 And not necessarily for the 535. From a quick google search it appears the Wagner model has the same mounting ears the BMS one. Same with my charge pipe. I run VTT’s 3” chargepipe with TIAL BOV and it wasn’t 535 specific.
Reactions: Kenjermen
Kenjermen
78
75
N las vegas NV
Did u have to make brackets for the intercooler? Or mod some stuff for the charge pipe to fit? Thanks for the info
Rickz96
I did have to fabricate the brackets. Grabbed some angle iron from Home Depot and MIG welded it together. Painted black and attached where the bumper goes. Tucks in nicely.
Reactions: Ty_Bo and Kenjermen
Rickz96
No issue at all man, I went into this blind years ago as there wasn’t many folks modding the 535Xi’s. I’m happy to help.
Regarding the charge pipe - I had to relocate my power steering pump as the lines were getting in the way. I don’t recall if it was because I went 3” but either way it was tight and I just moved it over to the strut/headlight area. I didn’t make any type of bracket there because I honestly forgot about it. The attached pic is from when I was fitting everything up. You’ll probably notice my car isn’t that clean. It’s a daily driver and have nearly 200k miles on it. My only issue lately is getting a transfer case to last more than 5,000 miles....
Ty_Bo
18
10
Livermore, CA
2009 535i
My understanding is the ER charge pipe is plug and play on the E60. VRSF w/ BOV is supposed to fit as well.
I went with BMS and DVs, While its a nicely finished product there was no way it was going to clear my power steering reservoir/lines (sport package car). I had the res off the bracket and still couldn't find clearance so I had to massage the CP.
I'm pretty interested in FMIC options right now, ARM has a pretty competitively priced solution I've been eyeing and so does VRSF. I'm just hesitant knowing a lot of E60 products are usually warmed over E9x specific parts
Ty_Bo
18
10
Livermore, CA
2009 535i
Rick did you do anything creative with the trans cooler?
