DSC Coding
ckh091020
33
I have an E89 35is and a 08 E60 M5, I coded the E89 with DSC_89.C03 to remove some of the DSC nanny stuff ( HVV,BSW,HHC , HPS specifically) everything went well, then when I try to code my E60 M5 with DSC_87 , the HVV, BAW , HHC are not available for some reason, I did a search on NCS Dummy, those options apparently in different file(module maybe?), it is in DSC8_PRA and EHB_60 , I ran through the complete list of the ECU module in the NCS expert, I can't find those module, so my question is, anyone where those functions store in the E60?
LMB335is
301
189
FOB FL
13 335is
Make sure your reading out the right module to code. First for a M5, the DSC module should began with MK60_M5.Cxx, secondly, M3/M5 DSC software doesn't have the electronic nannies that non M DCS software has.
ckh091020
33
I learned something new thank. Yeah it is MK60_M5.C05, I was asking because I want to have it adjustable ,if not mistaken both should be MK60 and MK60E5 I want to see if I can flash the non M firmware to the dsc or hardware change require?
ckh091020
33
I got a used DSC and swapped it into E60, loaded with ZB 6862873 ( Yes, I aware it is E8x firmware), flashed ok, calibrated SZL , turn signal worked, recalibrated all pressure sensors, got ABS light off, then tried to NCS code the module ( had to change E89 VO), MK60_87.C0F , A_E65.IP0, DSC_87.PRG pop up, Daten V.61. got error COAPI-2062, just curious the error because of out of date? or what is it?
135boost
248
Finland
135is
Hi.
I have a issue change max cruise control speed from my dsc.
I don't find whole dsc module from ncsexpert so how to change one parameter wert from 02 to 01.
Setz_v_max_cc is now value 02 what is 155kph and i need to get that to value 01 what is 250kph.
This is transfer case clutch related tests to figure out if cc has anything to do with speed related clutch realacing.
