dry break fluid line fittings?
The Convert
1,487
1,054
Anyone on here have any experience with Dry Break quick connect fittings? I've found a few options out there by Staubli, Aeroflow, Jiffy-tite, and Radium. I'm sure there are others as well. My plan is to add these fittings to my fuel lines, oil feed and return for the turbo, and coolant feed and return for the turbo to make it super quick and easy to remove/inspect/reintall/swap components out without having to drain/fill/bleed fluids. In time, I'd also like to add them to the clutch line and the brake lines. I believe the Staubli ones are the only ones rated at a high enough pressure for brake line applications though.
Staubli: https://www.pegasusautoracing.com/keywordsearch.asp?KeywordStart=staubli&KeywordButton=Go
Aeroflow: https://www.pegasusautoracing.com/group.asp?GroupID=AFQR
Jiffy-tite: https://www.pegasusautoracing.com/advcat.asp?CategoryID=JIFFY
Radium: http://www.radiumauto.com/Dry-Break-Couplers-P1003.aspx
What are your guys' thoughts?
The Convert
1,487
1,054
Good info. So far I'm leaning towards the Jiffy-tite fittings for blend of function and price. I'll likely be sticking to the motorsport grade Staubli fittings though for high pressure brake and clutch lines.
