Delete
4,348
Good theory, all makes sense. I got a buddy going over to check later. Hopefully belt broke and it got sucked into front main seal, so I can finally walk away from that car. It’s cursed. For real.
Maybe the axle got stuck in the transfer case again.
  • Dumb
Reactions: fredcase
Seaneezy
133
34
e90 LCI 335i
seems like something IBS (intelligent battery sensor) would throw at you. I was specifically having that steering angle code before I got a new coded battery that fixed it.
Reactions: fredcase
Rcboosted2007
902
90
Parts unknown
07 335i
Just a guess, but did you check your fuse for the coolant pump. Its a large 40-50amp. Also check the “ fuses” on top of your battery. The red cable/box attachment is actually a set of blade fuses
Reactions: fredcase
1,929
664
Their was a recall regarding the cable that runs behind dash and glove box. I believe it Is all lhd so yes Canada should have the issue. What MY and chassis is your car I'll see if I can get info if campaign covers you in Canada
1,929
664
People were having their cars burn down cause of the short from battery cable recall I was referencing. Reading high voltage is confusing though. That was an internal reading from cars sensor or a voltmeter connected to car?
Reactions: fredcase
Tiron
23
BMW 135i
A while ago I had the voltage regulator go bad in my 2007 335i, dashboard lit up like a Christmas tree. Trans light and everything. When the voltage goes over about 16v, the water pump shuts off (and I'm sure other things as well). Get a multimeter and make sure your voltage is in spec.
JimboFresh206
289
152
335/635/535/533/633
Can confirm on the voltage regulator whackyness, mine had the added benefit of acutally igniting the blower motor wiring when it went (along with the super awesome shut down the water pump on the express lanes and every light possible) lol
Replaced the reg and voltage went back to.normal instead of the 16-19v it was trying to put out.
Dead alts usually whine, squeak, and have low output.
27684
Reactions: fredcase
