delete
dyezak
1,767
1,518
Plano TX
335is
So, i did a valve cover gasket and an oil filter housing gasket. got these codes.
Then i removed, cleaned and swapped vanos and got the 2nd set of codes.
Should I be trying to get some new vanos sonoloids?
The screen shots are exactly the same. Did the codes change at all?
dyezak
1,767
1,518
Plano TX
335is
So how did you clean up the oil mess? It looks like you have a single vanos solenoid failure (it followed your movement). And what oil did you re-fill with after your maintenance? Some oil (redline) has been known to cause faulty oil condition sensor codes. Simply going to a standard oil generally makes that go away. I'm going to say attack one of these at a time though. And the oil condition sensor is just an informational code, so it won't cause the limp mode....the vanos is what's hurting you so I'd replace that first.
