DCT Gasket failure
NoGuru
1,203
586
Just North of Detroit
BMW 335is
Just got back from my Indy and they found my DCT is leaking pretty bad from the passenger side of the DCT. They quoted $1100 to reuse the fluid and filters and $2K for new fluid and filter change. I have 56K on the odometer.
Just looking for any feedback on what others think.
I might just do the fluid change now instead of waiting until 80-100K.
2,232
793
The side pan requires the box to come out and that’s a lot more hours to charge than the bottom. A lot of people reckon it’s not the side pan but a breather on the top of the box instead. I would clean the box and be sure where the leak is from first. I’m in the same position
4,291
Another $900, and yes, seems very excessive. It's the only BMW Indy I know of near me. Might have to start looking further away.
I took the cost of new fluid into account, so that leaves around 500-600 for the filter changing.
Bmwfixerguy1
872
290
07 335i MT
You are supposed to take the box out to replace it but you can sneak them out by lowering it a little. Yes the side covers leak a lit on these things as well as the pan cracking . The filter is built I to the pan ao it's quite a bit of coin. Owning a dct car can be expensive.
Reactions: aus335iguy
