Darton sleeved block
STE92
224
83
E92
I have a 6870… wish i went with 6875 little more breathing room. That 8080 going fit that mani?
Yeah I was gonna get the 6870 but then doc vu said get the 6875 and I didn't even know that turbo existed but in glad I didn't get it. All the dyno graphs and data I've seen show the 75 turbine wheel helps move alot of exhaust gas. I imagine the 8080 would fit. I've seen some kids put 76mm borg warners which are notoriously large compressor housing and it seems to fit alright. I realistically won't be needing the 8080 until I add nitrous and a standalone and maybe an automatic transmission. Not sure how id keep that thing spooled with a manual. Just wouldn't be fun on the street anymore with a 8080 I can't imagine
Reactions: STE92
@SLOWESTN54 Just the manifold right? May or may not have dyslexia and may just send you the spa manifold. The both start with S and are cast so they have to be the same thing right?!?
@SLOWESTN54 rumor on the block is you can't fit anything bigger than a 7675 down below. So youll just have to settle for a top mount like a man
STE92
224
83
E92
Definitely cant wait see some pics!
Little update. After only lasting 2 hours on a brand new vdo waterpump from fcp, they sent me a new pieberg and its been running good and staying cool now. Got the car in map 3 right now and it pulls really strong for 20 psi. I previously lifted the head on 23 psi with stock head bolts. Only issue i have is I seem to have developed a small oil leak from the rear main seal, so gonna swap that out and see what 30 psi does.
