Coolant reservoir relocation 90 degree fitting available? Need some advice
InnovativeAuto
76
21
Z4
In the middle of relocating my coolant tank and have hit a snag. My plan was to remove the 3-way fitting on the pump outlet and replace with a 90. To my surprise I cannot find a part number for a 90 fitting. I have just found a 45 made by Dorman. Does anyone know of a part# for a 90 fitting? I should have just plugged the 3-way! I can probably use the 45 but it would put tension on the hose and I would have to file off the tabs on the connector to orient it correctly. On the drivers side I just T’d into the line. What to do?
1,054
I am super surprised you were able to find any Dorman fittings for sale. When I was searching, I couldn’t find them anywhere.
iminhell1
419
207
Everything you need is already on the car. Just have to move them around.
The Y from the therno goes to the bottom of the upper rad and the 90 that was there goes to the thermo.
Then the only new hose you need is a section from the thermo to the heater pipe.
Like so (you may need that photobucket add-on)
https://www.n54tech.com/forums/showthread.php?t=46320
Reactions: The Convert
InnovativeAuto
76
21
Z4
The Z4 does not have a 90 fitting on the upper rad. It is a 45 which doesn’t help unfortunately.
Anyone have the part# to the Y fitting? I think the only way here is to plug one side. Too bad I ruined mine when I took it off.
iminhell1
419
207
Shoot.
Well the Dorman (VW) fittings are clocked different. You have to shave down the nubs on the BMW side to get them to rotate correct.
I still have them somewhere if you happen to want them.
InnovativeAuto
76
21
Z4
I think I found a solution. I was looking at bmw coolant lines on eBay and saw the X5 has a 90 of its reservoir. Going to buy a used hose w/fitting for $10 and use the fitting from it. Looks like it’s clocked correctly too.
Reactions: iminhell1
