Coolant Expansion Tank Fittings?
NoQuarter
1,662
1,067
Indiana, USA
Z4 35is, 535xi, X5 35i
I am looking for fittings (Dorman?) That connect to the Coolant expansion tank lower fitting. OEM fittings are part of the hose assembly and are not available.
Cutting off an OEM fitting is very difficult to use because of the size - OEM hoses are flared to accept the large connection. Stretching a hose to go over that connection is less than satisfactory.
Dorman makes some that look the same, but are only listed for Audi and VW.
In the mean time, I have ordered a few varieties to try out.
Anyone know of any that fits?
iminhell1
419
207
Just buy Silicon coolant hose, bulk, and cut to fit. It'll fit just fine.
Yes the Dorman ones fit (I don't recall the exact size) but they are clocked differently. You need to grind/file the alignment tabs out.
A secondary option is to just buy used stuff from ebay and get the fittings you need that way, or salvage yards.
I picked up a lower coolant tube (auto to manual, removing trans cooler line) for about $15 shipped.
Rob@RBTurbo
626
404
St. Louis, MO USA
www.rbturbo.com
'08 335i, '14 M6, '15 Tundra
We custom made this prototype several years ago. Never put it into production, but if there was ever any demand we could.
Rob
NoQuarter
1,662
1,067
Indiana, USA
NoQuarter
1,662
1,067
Indiana, USA
This is what stretching the hose to fit looks like. just trying to do better than this.
26864
NoQuarter
1,662
1,067
Indiana, USA
URO Parts fitting URO-008160
45deg neck
This fitting fits nicely but It is clocked so that it points up towards the hood.
26887
