long time without any upgrade to project.
so, it took almost 1,5 month to get my 135 fixed and painted after that accident so it stretched the project by
a bit but here is the state at the moment
there was some issues after issues, most with electronics not attempted at first to e82.
mechanical assembly some 55h , problems at start is not to know what to swap, what fits and what not and assembly
sequence to all.
my e82 was manufactured 08 2007 and donator 335xi 09.2008.
to be swapped
-engine
-subframe
-tranny
-front struts with halfshafts
then to the not so tricky parts.
i wanted to keep 6 pot front brake calipers
so i have to make my own front discs from 335xi discs
prop shaft has to bee shortened by 99mm
downpipes is a mess to fit 4by4 because it`s to a 2wd
exhaust must bee modified cause of longer tranny (berk)
double barrel shotgun didn`t fit so i have to dump a/c to get that fit.
4x4 tranny crossmember does not have place in 135 and tannys transfer case does not fit in 135.
some small issues not to mention here.
the real issue is electronics and how to get everything work as mentioned because difference in modules, wiring harness etc.
first begin with swapping all modules from that donator just to figure out that there is no place for transfer case module but that
connection was not so difficult to dig out from tis
nightmare was to figure out that abs module is totally different on a xi than non xi with different contactor and very different pin layout so
first i did modification on wiring harness to get those modules fit just to figureout that acceleration sensor is totally different pin layout
and connector type.
then came problem with wrong abs sensors (gray ones) what should be blues, but blues did was not plugnplays. some 5 hour went with
struggling of not get speedo work until i discover that right rear wheel bearing was faulty and grey sensor was that little bit more sensitive that it worked
but throwing 4x4 faults.
i swapped that nice looking steering wheel from my donator and dashboard came from 335 too cause of right 4x4 warnings etc. but that caused
more problems, 335 dash is 5mm higher than 135 so there was modifying too.
after that i have use some 80 hour just to solve small electronic and programming issues one after another using tis, ncsexpert, inpa, ista end so on.
most time has gone with learning to use those programs and just to figure out issues that come on these kind of maybe first in world projects but is have teached me quite much on BMW diagnostics.
one of the biggest pain in the ass was fault code 5087 what seems to be mystery all over internet and i think i know reason for that. (my taught)
Bimmerforums is the preferred online BMW Forum and community for BMW owners. At Bimmerforums, you will find technical how-to information maintenance specifics audio advice wheel and tire combinations and model specific details not found anywhere else. Our professionals are here to help make...
www.bimmerforums.com
this kind of complains is to be found on web but there seems to be no one to tell how to solve or find real reason for it.
there is 2 different wiring harness and different transmission egs, different paddle shifter steering wheels and if you swap one of those
you can find you selve on 5087 problem. older paddle shifter use feed from paddles to gear shift lever with one upward wire and one downshift wire
going from paddle trough button assembly straight to manual gearshift swithes. paddles seems to be same with 100 ohm resistance but
resistance is messed somewhere inside steering wheel button plastics cause i xross tested parts and 135 upshift downshift version works but
the newer one wire didnt.
from on 03.2008 there was changes on that wiring, using exact same pin numbers from junction boxtrough steering wheel but there is not 2 separate output
like on older ones, on newer there is ground as one of those and one wire feed back from steering wheel trough junction box and x6021 connector straight
to transmission pin 12.
that 5087 fault code is missing resistance on one pin (12)and it must be solved with adding that cable, modifying wiring harness, or changing firmware in egs
not to waiting for pin12 be active. on newer egs gear change is done by resistance difference , my guess is at rest 300 ohm, upshift 400 and downshift 200 ohm, those values should be measured from working tranny to get that but my wiring ofcource miss the whole wire.
sorry for my english but i really hope this help someone in future.
state of the car is that all rest fault codes has been solved except seat occupancy and some head rest airbag.
then charcoal pump is missing on my car, it was usa version and there is a difference between euro and usa firmware
and now system is searching that missing pump.
next to test xdelete, xhp and trebila jb4 on this.
