Coil pack question
ysjeon1698
79
14
Texas
Do I need to replace all 6 coils when only one cylinder is misfiring?
if I just need to replace only one, can I use different brand? or do I need to use matching brand?
Cheezy
611
225
Toledo Ohio
Only replace which one is misfiring, and I had three different brands in my car at once but fyi Bosch are the most durable imo. The delco rip and get stuck on the plug and then if you don't have the know how and tools it's a mini panic to get it out. Are you certain it's the coil causing the misfire?
ysjeon1698
79
14
Texas
Yesterday, i moved coil from 5 to 3. Then I deleted the code. I just need to test drive for couple of miles with wot to see whether the error follows or not. If it doesnt follow, I will assume it's the spark plug problem....
Cheezy
611
225
Toledo Ohio
You have done the right thing young one :D ha good luck with solving your misfire!
ysjeon1698
79
14
Texas
Okay, test drove today after replacing coil from cylinder 5 to 3.... drove for 30 min, and gave one wot. Car runs great... no more misfire... weird. what is the problem lol??
