Cat Cams vs Schrick?
4,301
I remember hearing about these a couple years ago and nothing came of them. I suppose they finally came through?
For reference, Schrick: 268/268 12.5-Intake 11.0-exhaust
So do you think the longer duration and slightly smaller lifts are better than the bigger lifts and no duration?
FRNTHVY
84
24
I have always preferred more lift and stock like duration for turbo cars. That is just me though. I have had good luck with CAT Cams in the past and was excited to hear them make an offering for the N54.
4,301
I think there is the element of fighting the VANOS as well if the durations are changed, I'm curious if they have actually tested this. What did you run CAT cams on before?
FRNTHVY
84
24
I used CAT Cams in my old VAG days. They worked well on the 18T's. I do not have personal experience outside of that.
Sam
Jsherry20
313
Cat makes good shit for the VW 1.8 guys, custom grinds as well according to a friend. I'm curious if anyone is seeing results with a PNP head and worked over valvetrain.
FRNTHVY
84
24
They sure do! I had 282°/269° - 240°/222° - In my car and it really helped the top end. That was back in 03-04 though when 580whp was a big deal out of a 18T :p
Dec 14, 2016
40
28
Interesting specs CatCams has for the OEM camshafts. We had a set analyzed a while back and here is what they found.
Remember to multiply all lift values by the 1.66 rocker arm ratio.
Notmpwr
535i
Does anyone have any head flow data?
Without a flow bench it's pissing in the wind on lift. Most the time duration is not as critical on a fi engine to make power because you can only get so much cylinder filling before you start killing the power under the curve in place of just a few more peak hp .
The biggest thing with any fi engine is lsa, which is adjustable on our engine so that's a mute point between camshafts.
Notmpwr
535i
There's a number of companies/individuals offering "upgrade" cylinder heads for sale. Maybe one of them has done the testing.
It would be nice to see that data.
If they are doing any port work they would definitely have that data because porting without a flow bench is just retarded. Most the time people kill velocity and gain nothing in flow.
Dec 14, 2016
40
28
For those folks who don't know what "LSA" means, or for that matter, "Lobe Separation Angle", here is a graphic representation of the two cams at a typical 108˚ from Top Dead Center:
The separation angle determines the degree of overlap in these two curves.
4,301
I've seen flow bench results from VAC and one or two other people of the stock head. Lets just say, they clearly didn't use the same benching station.
Reactions: [email protected]
dyezak
1,768
1,518
Plano TX
335is
And to explain "why" LSA is important (using that awesome graphic) you have to remember in a boosted environment you are actually cramming your combustion chamber full of air under pressure. If you have overlap (that small section where the two lobes cross over in the graphic, this is actually when both the intake valve and exhaust valve are open at the same time), what you are effectively doing is cramming all that boost right out your exhaust. You don't want overlap in a boosted environment as it is a giant boost leak straight out your combustion chamber into the exhaust right when you are trying to fill that chamber with fresh air.
You want that overlap in a NA environment because you are in a negative pressure state and it creates a scavenging effect which effectively sucks more air into the combustion chamber. At that point the exhaust pulse has gone down the runner of the exhaust manifold or header, and has left a negative pressure zone behind it. That negative pressure zone is under vacuum and effectively sucks air in from the intake manifold during overlap. This is also what gives that lope-y cam sound we are familiar with.
LSA is a massive influence on all engines, it just works differently (and oppositely) when you are in a N/A vs. Boosted environment.
So, why is it that people have gravitated to lift being good for boosted engines and not duration? I'll explain with that graph again. See the tiny area of overlap between the two lobes? Well if we increase lift we don't impact that area at all. We just take those existing lobes/peaks and make them higher. We have effectively increased the area under the curve WITHOUT adding any LSA (which would be an effective boost leak in our engines). Now if we increase duration we are making the lobes wider. Well, if we make the lobes wider we are decreasing LSA, adding to the boost leak, and losing some benefit of cylinder filling under the curve.
BUT!!! We have full VANOS control! What does that mean? That means in theory we should be able to run cams with increased duration IF we completely remap all the VANOS tables and retard the intake cam a bit and a advance the exhaust cam a little. That would effectively move those two lobes apart on that fancy diagram, thereby removing the additional overlap we induced with increased duration, and giving a greater LSA.
So the old adage that adding lift is better than duration for a boosted engine was on old statically timed cams. An environment where adding duration would inherently add overlap (which is bad for a boosted engine).
We don't live in that world with VANOS, it would be a completely new thing to re-tune all the VANOS tables to take advantage of CAT cams...but it would be possible.
