Dripn54
Datalog Can someone help me figure out what’s wrong with this
MR-KRAKA
85
Reactions: OneStunDone
Dripn54
Stop now or you will be melting a piston soon. Stock fuel system? Trims maxed out on bank 2 and getting dangerously lean. Must be running upgraded turbos with an ots MHD tune? DME is doing all it can to get load/boost in control. You will need a custom tune and supporting mods if you have upgraded turbos.
Yes I do have stock fuel system and I just got pure600 turbos installed and car is fbo on MHD 2+ tune. If you can give me some recommendations on what to do will be appropriated. Also I’ll try attaching another log after this came a misfire clears it did another log no Misfire car ran great. https://www.spoolstreet.com/graphs/log-05-20-2022-00-40-57.17933/
MR-KRAKA
85
You are going to do major damage if you keep thrashing on the car in this state. Just baby it around if you must drive it. At the very minimum you will need a large single fuel pump upgrade, 3.5 bar map sensor and a custom tune from a tuner of your choice. That is assuming all maintenance is up to date.
Dripn54
Yes did a bunch of maintenance while car was at the shop getting turbos done okay thanks I’m going to look into getting these
MR-KRAKA
85
All depends on your goals, fuel type etc. be prepared to provide that info when shopping tuners. If you’re “FBO” with upgraded turbos and ALL maintenance is good. It’s down to the fuel system really. Port injection and controller if going full e85 or an hpfp overdrive or even a methanol injection kit. Without any of those just the low pressure fuel pump upgrade should support around 500whp on an ethanol mix. You should also get yourself upgraded coils if you haven’t already especially with misfires showing up.
