Dripn54 submitted a new graph:
Can someone help me figure out what’s wrong with this
View this graph...
View this graph...
Stop now or you will be melting a piston soon. Stock fuel system? Trims maxed out on bank 2 and getting dangerously lean. Must be running upgraded turbos with an ots MHD tune? DME is doing all it can to get load/boost in control. You will need a custom tune and supporting mods if you have upgraded turbos.Dripn54 submitted a new graph:
View this graph...
Yes I do have stock fuel system and I just got pure600 turbos installed and car is fbo on MHD 2+ tune. If you can give me some recommendations on what to do will be appropriated. Also I’ll try attaching another log after this came a misfire clears it did another log no Misfire car ran great. https://www.spoolstreet.com/graphs/log-05-20-2022-00-40-57.17933/Stop now or you will be melting a piston soon. Stock fuel system? Trims maxed out on bank 2 and getting dangerously lean. Must be running upgraded turbos with an ots MHD tune? DME is doing all it can to get load/boost in control. You will need a custom tune and supporting mods if you have upgraded turbos.
You are going to do major damage if you keep thrashing on the car in this state. Just baby it around if you must drive it. At the very minimum you will need a large single fuel pump upgrade, 3.5 bar map sensor and a custom tune from a tuner of your choice. That is assuming all maintenance is up to date.Yes I do have stock fuel system and I just got pure600 turbos installed and car is fbo on MHD 2+ tune. If you can give me some recommendations on what to do will be appropriated. Also I’ll try attaching another log after this came a misfire clears it did another log no Misfire car ran great. https://www.spoolstreet.com/graphs/log-05-20-2022-00-40-57.17933/
Yes did a bunch of maintenance while car was at the shop getting turbos done okay thanks I’m going to look into getting theseYou are going to do major damage if you keep thrashing on the car in this state. Just baby it around if you must drive it. At the very minimum you will need a large single fuel pump upgrade, 3.5 bar map sensor and a custom tune from a tuner of your choice. That is assuming all maintenance is up to date.
And anything else while I’m searching for partsYes did a bunch of maintenance while car was at the shop getting turbos done okay thanks I’m going to look into getting these
I’m going to start with the lpfp upgrade and a new 3.5 bar sensor and a custom tune for the car and if this doesn’t resolve anything then go for the hpfpYour HPFP crashes heavily. Start looking there.
