Buy this, Not that!
VACust
112
53
US - Utah
I always thought automatic wire strippers would not work well. Then I bought a set. They are awesome.
Is there an equivalent at non snap on prices? Hard to justify for a hobby mechanic.
https://protoolwarehouse.com/8-1-2-bahco-universal-pipe-wrench-140/
The first link was a larger set that I was ordering today. I have the 8.5”, 14.5” and 11”. Those 3 range from $42 to $50 each.
I just bought the 21” and 28” today.
This thread made me organize my tool box. I just went through a Milwaukee “Fuel” brushless motor buying phase. Threads like this aren’t good for a tool junkie to not spend money.
Tool junkie, eh? Ok here's a $100 ticket one can spend for the Milwaukee tools. Got this idea from a garage forum to which I belong. Kobalt Charging Station available at Lowe's. Powder-coated steel, full power strip at top. Comes with a french cleat if you wish to wall mount. Very reasonably priced @ $90. Sticker up the station however you like. :sunglasses:
p.s. If you own the Milwaukee work light 49-24-0146, swap the incandescent light with a CREE LED upgrade. It was a nice improvement.
VACust
112
53
US - Utah
That's almost an addiction. I even went out and bought the brush-less chainsaw. Who doesn't need a super quiet chainsaw?
I prefer their Fuel line over any of my old air tools. My 1/2" Milwaukee impact is as strong as my 3/4 IR if not stronger. We were using it to break lug nuts loose on an old surplus AM 5-ton truck the other day. Broke all of them loose with no issues.
I agree. Running around with a hose is a pain in the butt, not to mention that there is better accessibility without the hose and coupler hanging off the back end of the tool. Once you invest in some batteries and chargers the incremental tools aren't that bad. It's important to only buy the fuel versions.
Reactions: VACust
VACust
112
53
US - Utah
You’d like the heat gun and soldering iron. Doing wiring with no extra cords hanging around makes you appreciate the battery powered stuff as much as the non-air tools.
The rivet gun is nice. When the stem breaks off it didn’t seem to bounce and scratch the river head finish like a standard riveting plier.
The die grinder is to big. It’s the only Fuel line tool I haven’t liked more than my Snap-On Air tool. It was meant for larger metal work than what I use it for. Hopefully they can come out with a die grinder that’s between what they have and their 12V Drexel size rotary tool.
Reactions: fmorelli
MattGu40
36
14
335xi FBO
You sir just created a URGENT NEED for this
Reactions: VACust
MattGu40
36
14
335xi FBO
Reactions: VACust
VACust
112
53
US - Utah
Ok ... let's talk screwdrivers. Another pet peeve of mine. Part of the reason is that I work on expensive guitars where one cam out of a screwdriver head can cause me to destroy a guitar finish. Sometimes the same holds true with automotive screwdrivers, but the greater issue in automotive is higher breakaway torque necessary to loosen some screw fasteners. Thankfully BMW uses Torx a fair bit, which is a far better fastener (that's a whole other conversation - screw head vs hex vs torx).
I no longer use cheap screwdrivers - life is too short. A good quality screwdriver can provide several benefits:
  • induction-hardened tips that better withstand wear.
  • laser-etched tips for greater cam-out resistance.
  • handles which support applying greater fastener torque.
There are a number of good brands. I'm going to focus on three specific brands, and give some suggestions.
The best high-torque screwdriver in the business is Stahlwille 3K Drall line. They are not cheap. 8 piece set is about $120 out of Chads Toolbox. If you are sensitive to price, they have a smaller set. This is my garage go-to set of screwdrivers.
For my guitar shop, where I have less of a high-torque requirement, I prefer Wera. These are not as expensive and 80-90% of the screwdriver Stahlwille makes. Also easier to purchase in the USA. Their 6 piece set is about $42. If you don't want to break the bank, this is a great screwdriver.
Then there are the electronics and specialty screwdrivers. I have a variety of sets, again from Stahlwille and Wera (here and here). But I also use Wiha, which are excellent. Specifically I recommend the Wera and Wiha models for cost, quality, and handling. Unlike the larger screwdrivers, tip sensitivity and balance is an issue when handling small fasteners. Note you might do a bit of research as they come in different size sets.
Finally to throw out a slightly off-the-beaten path recommendation. I recently purchased this set of long-reach Wiha screwdriver set and am very pleased with them. Not unwieldy but long enough to reach when it is needed.
gorspeed
76
27
Columbus
View attachment 14946 View attachment 14947
I swear you are posting my own toolbox :tearsofjoy:. Are you by chance a GJ member?.
While those screw drivers are very nice they are missing a hex bolster for extra torque. which is quite useful for automotive applications.
https://www.kctoolco.com/wiha-53398...-heavy-duty-slotted-phillips-screwdriver-set/
I am personally between those and the snapon set:
https://store.snapon.com/Instinct-1...Combination-nbsp-Screwdriver-Set-P645279.aspx
But of course ... :sunglasses:
The two screwdrivers you show are excellent - can't go wrong!
My experience has been that with a screwdriver with a good grip, one can supply enough torque to break most any threaded screw free (unless seized, in which case ... well ... topic for another post). But the Stahlwille's are expensive in that regard. When I was in the biz, all that stuff was 40% less than retail, so it helped take the bite off, of course.
VACust
112
53
US - Utah
I like the Wiha impact driver bits. https://www.wihatools.com/bits/terminator-high-performance-impact-bits
I have a Snap-On manual impact driver and use Wiha bits. They’re an awesome combo for taking off stubborn/rusted BMW brake rotor screws. I think the shielded Snap-On driver is discontinued but I bought one of these in a pinch when fixing a vehicle in the middle of nowhere. https://www.jbtoolsales.com/otc-460...MI1d2xp4D13AIV07rACh2b_QjeEAQYCyABEgL_3vD_BwE
The Wiha bits are still a necessity in my opinion.
