Built engine high RPM hesitatiom
STE92
224
84
E92
Just recently completed breaking in my engine and started the tuning process. Having a weird issue at high rpm, bank 1 AFR goes lean 20, car hesitates for a second and continues. I was thinking hpfp going bad, fuel pressure deeps for a second and recovers doesn't affect bank 2. I get no codes, any help will highly be appreciated? I'm running on fumes
N54
Closed deck block
JE pistons 10.5.1
Molnar rods
Arp bolts/head studs
Maximum psi hub/vtt bolt catch
P&P head
Supertech valve train
Shrick LL cams
DocRace kit GTx4088r
DocRace IM 750cc inj/index 12 inj
PR stage 3 full E85
Vtt shotgun
Vtt dual catch can
Jb4/mhd (v8bait)
Additional information
FirmwareInterfaceEngineTMAP_VAvgIgnDWPMethTriggerModeFFMethSafeModeMethAddMethScaleMethPSIVINE85_SetupVFF_Offsetfuel_30fuel_35fuel_40fuel_45fuel_50fuel_55fuel_60fuel_65fuel_70
30/139//2JB4 Android A330E Series - N541.9622.12401800990.0............NONE132505050505050505050
BoostSafetyPID GainAutoShiftRedFuel_OLFUA1st_limiter2nd_limiter3rd_limiterOptionsN20_TMAP6CylModeLastSafetyduty_15duty_20duty_25duty_30duty_35duty_40duty_45duty_50duty_55duty_60duty_65duty_70
26.0250000.00.00.0NONE141505050505050505050505050
  • P30_M4_R1_200817_075307.csv
STE92
224
84
E92
Hi,
double check the spark plugs. Maybe one is loose.
Has new plugs gapped .018, torque to spec, reset adaptations with INPA, went back to stock coils from BL, moved my o2a...make sure woring wasnt close anything electrical. NO Change. Really running out of options here
Slowagon54
207
96
I am sure you have discussed the issue with Justin. What is he saying?
Timing for 3 goes flat for quite a time. It should go up again, but it does not really. Trims for Bank 1 is off as well. So you may have a closer look at cyl 3.
STE92
224
84
E92
So Justin, thought that maybe I was looking at some kind o2 wiring issue. I decided to remove the IM to inspect the junction box and the o2 wiring under the IM. I found that my O rings/manifold gaskets looked flat and u can see trace mark of the areas were it was leaking un-metered air into the cyl not sealing. I ordered new ones coming in today, I also inspected wiring make sure there are no issue there. Will report back with results.
Slowagon54
207
96
Makes sense. Thats why i asked to check the plugs. I had a few loose and got plenty of corrections and lean condition. Took me some time to sort it out...
