I'm currently running a fully forged N55 PWG with a hybrid turbo machined to fit a G35-900 core with a PureTurbos WG.
Running JB4 + BEF (yes, I've tried to remove JB4). I have used JB4 for a long time, and I'm 100% sure that's not the issue, mainly because there is a guy in Germany doing 1000WHP on a JB4 + BEF (but he's EWG).
The log:
https://datazap.me/u/gengis/n55-hybrid-g35-900-3-gears-boost-tanking?log=0&data=1-3-4-11-19-29
Pull 2nd to 4th gear to show how, when shifting, the boost goes up again.
Tests done so far:
Given that there are no boost leaks, and how the log looks, I'm leaning towards a broken vacuum line or a bad solenoid.
How does the solenoid work? If the solenoid couldn't hold the vacuum or the vacuum line to the WG was blown, would the solenoid know the output vacuum and try to overcompensate that moving the WGDC to 100%? Currently, it's holding at around 80%.
Do you see anything else in the log that would lean more towards one of the theories or even another one?
Any help/ideas are welcome!
Thanks!
The log:
Tests done so far:
- I ran the smoke machine for around 30min, no leaks whatsoever smoke machine did around 3psi (in case that matters), but I'm quite sure it reached 10psi at least due to the amount of pressure released when I removed the smoke plug).
- I plugged a custom tube to the WG, it's correctly adjusted and it fully opens at around 5-6inHg, but it doesn't maintain vacuum (probably my MityVac has a broken seal or something, I'm quite reluctant to think that the brand new WG Actuator from Pure is faulty, I will test another MityVac tomorrow.
Thanks!
