Hey Spoolstreet,
Need someone's opinion on this, there's a data log below this paragraph but wondering if this is a boost leak causing this slow boost build and unreliable boost up top not hitting target earlier, I do have terrible engine mounts causing the engine to rock between gear changes which is getting changed next week, but I would expect that maybe the issue is due to the mounts being so bad, causing a leak from the CP or something, pretty sure I'm on the money but wanted to see if anyone sees anything else or agree that it's a boost leak...
- https://datazap.me/u/bslothed/boost-leak-sloppy-boost-build?log=0&data=2-3-4-12-28-29
Thank you.
Dylan
Thank you.
Dylan
