02/07 Mod #9 MST 2021+ BMW G80 G82 M3 M4 Competition S58 Cold Air Intake System BW-S5801]
In this video, we install the MST 2021+ BMW G80 G82 M3 M4 Competition S58 Cold Air Intake System BW-S5801.
Note #1: Nothing was wrong with the BMS; we are pleased with the quality, sound, and fitment. We only did the exchange to test a different intake. We wanted to switch from a front mount intake to a stock location air intake.
Note #2: had we had the stock intakes instead of the BMS one, the install would have been lots easier and less time-consuming; since the BMS intake is a front-facing one, the install/uninstall takes more time. We also did not have access to a lift and did not want to remove the bumper as we did on the install, link:
Features
* Maximizes airflow to the engine.
* High-quality laser cut heat shield helps block hot engine air
* Better throttle response and more exciting sounds
* Can be upgraded to the original power programming or Stage 1-3 programming
* High-flow air filter, easy to maintain
Fits
