BMW 320i Error codes
salamgir
Hi All
I am new to this forum, if there is certain etiquette to follow let me know.
I've got a second hand BMW recently and have basically been scammed where the seller said all was good. Once I bought it, and started driving, the car dash came on with a engine management light. The seller has disappeared with my money and scammed me into buying this broken car.
Once a OBD reader was plugged in, it came with the below faults.
There are quite a few codes I don't know what they mean. I hope this group is able to help. I would appreciate if there was any solution any one could point me to.
Should I erase the codes and rescan and see what faults come on, and also while I'm driving at low speeds the engine management light doesn't come on.
CAS Car Access System
  • A0C1 Output Terminal 50
  • A0C2 Output Terminal 50, RS
  • A0B4 Engine Start, Starter Operation
ECM Engine Control Module
  • 29CD Combustion Misfires Cylinder 1
  • 2E19 Firing, Cylinder 2
  • 2E18 Firing, Cylinder 1
  • 2E1B Firing Cylinder 4
  • 2D06 Air Mass System
EPS Electronic Power Steering
  • 63F5 Reduction Servo Power due to low supply voltage
JBE Junction Box Electronics
  • A6D0 Control valve in A/C compressor
  • A6CF AUC Sensor
INSTR Instrument Cluster
  • A559 Instrument Cluster power supply has been switched off (closed circuit current cut off relay)
FZD Function Centre Roof
  • A670 Fogging Sensor
  • DE88 LIN Bus wire fault
RLSS Rain Light Solar Sensor
  • A129 RLS Rain sensor on window not calibrated
FRM Footwell Module
  • E598 no message (driving lights)
  • E596 no message from Autobeam
MOST System Analysis
CAN Communication Analysis
