Yes has been done but a major pain as it's an 8 bolt crank, you can get a 8 bolt dct flywheel but its like finding Unicorns.
You can buy them new but extremely expensive, the actuall conversion is way to expensive and it would be cheaper to sell and buy a new car, not kidding.
Thanks for the reply Marty can you point me on who has done the pre March 2007 build date swap so I could ask them how it was done.
That hiccup with the 8 vs 6 bolt crank I know about. I wish I would've built my 6 bolt crank motor instead of my 8 bolt crank motor.
I have literally everything for this swap already.
DCT, Drive Shaft, 2.56 Diff, JBE2, DSC Sensor, DSC module, GWS, park lockout and an 8 BOLT M-Factory SM Flywheel (I don't mind if it is noisy or causes vibrations it's it's racecar haha) , Just missing the Axles.
My concern is that the AT wiring harness from build date March 2007 and back have diffrent plugs in the E-Box. Compared to the post March 2007 cars. I have been trying to use ISTA to trace all the wiring down but it is such a pain. I miss NewTIS.
I think if I can get the EGS talking on the CAN line I can just take all the wires out of the existing ZF6HP plug and use ISTA to tell me what each one does so I can put them in the correct spot on the new DCT plug from MAXXEcu.
Motorsportprodukter - BMW DCT 16-pol connector - MaxxECU
www.maxxecu.com
Thank you for the help I'm balls deep in the build. There is no going back now. It's either upgrade the AT or DCT swap.
