Introduction
I decided to make this guide since the only available installation instructions for this turbo kit expect that the work is done by a shop with the engine out of the car in a cradle.
Thanks to @AD-ENG for the hand holding and @[email protected] for various bits of engineering advice and @bdh for his input since he's done this already, on an E93 no less(less space).
Before you get started:
- This guide is an educational piece only, I do not hold liability for any damages to anyone or anything.
- I expect that you know how to jack up the car, drain fluids and uninstall the stock turbos, so no time will be spent covering those things.
- You'll need Red Loctite, 7mm stud extractor(useful for removal and install), copper spray, long 7/32 ball allen socket, 1/4 drive 11mm wobble socket, stubby 1/2" box wrench, hi-tack spray, silicone spray, harbor freight engine brace, ground down tow hook(so it screws all the way in). The copper and hi-tack sprays are only used once, so you're better off borrowing some.
- I highly recommend wrapping your manifold and possibly even putting a blanket on the turbo if possible. While it is a bottom mount and the hottest temps are kept away from your electronics, plenty of heat still makes its way up top.
- While you're doing this, you may as well replace your waterpump and thermostat since it gets removed in the process.
