Edit: just took the car for a spin nothing crazy no wot or anything, logged my voltage on KL15 with protool and noticed that I get Voltage fluctuations! While driving/idling it goes as low as 12.4V
So Voltage fluctuation from 12.4-13.8V car
Edit: checked voltage with multimeter (battery, under the hood terminals and alternator) all 14.4v at idle with all accessories on. Car off 12.6V
Edit: while checking the voltage at idle I gave it a little throttle (tiny bit) kept it there but rpms kept climbing to almost 5k (video is attached)
Edit: still have the feeling this might be Voltage related, not 100% sure if that’s true or not but that’s my gut feeling. I Unplugged the IBS sensor at the battery completely so it’s literally just a ground cable at this point,
Still not seeing 14V not with MHD and not in the hidden Menu 13.8-13.2 is where I’m at no matter what!
Came home from work pulled codes and got bunch of them picture is attached I wasn’t able to regenerate those codes also first time all those codes popped up since all this is going
Hello everyone, can someone help me out please?
2009 e92 N54 AT 6266 ST stock at with xhp s3
Since quite a while I have a strange issues going on.
A few month back (April or May) I installed my ST everything worked out well car ran fine on 14psi WG pressure then we started tuning
Got to about 19 psi and suddenly my transmission won’t stay in Gear/Mode example: DTC off M3 then wot and as soon load increases it will jump into either D6/S6 or D5/S5 usually nothing else happens also don’t get any codes (not in MHD and also no codes with xhp) and can just shift as nothing happened and keep on driving. But sometimes (same example as above) and transmission goes into safe/limp mode and stuck in 3rd til I turn the car off and on and everything works fine! That’s when I get codes please see picture!
I thought well time to rebuild my transmission so I did with PD clutches and bushings and a rebuild valve body I mean rebuild not just a sonnax zip kit!!! Installed the transmission did the relearn process etc. everything seemed to be fine and we kept on going now we are at 21psi but the one day same shit happens again car won’t stay in gear/mode! Then next day car drives and pulls fine for weeks and suddenly same shit again! It’s coming and going!
What I did so far! Changed our entire engine and transmission harness but not injector harness, replaced ground strap,replaced battery checked mechatronic sleeve connector to make sure it’s not leaking and plug sits flush 3mm from housing to plug as the ZF manual states, and as I said earlier it’s pretty much a brand new transmission! Sometimes it works fine then this shit happens and the next minute it pulls fine again! Please help I’m lost at this point!
TIA
Link to video if what It looks like
TIA
