335is DCT tune ?
DCT_JAY
66
16
2011 335is DCT
I messaged @V8bait and had no reaponse and was wondering if anyone knew of another person able to tune the transmission
DCT_JAY
66
16
2011 335is DCT
There is no tune for the transmission. At least not like XHP for the 6AT and 8AT. but hit me up, i can tune the car.
What method do you use , and i saw that people were doing a GTS tune changing the shift time time from 120 ms to 90 ms
LMB335is
301
189
FOB FL
13 335is
The GTS flash is M3 based DCT software. If you're willing to install a M3 GWS with all the prerequisite parts and change your final drive ratio to somewhere close to the M3 DCT ratio of 3.15 you can use it.
Reactions: DCT_JAY
Twisted Tuning
Oct 25, 2016
979
907
www.twistedtuning.com
N54 and N55 Cars
@LMB335is is correct. what i was trying to say is, there is no "custom" DCT tuning, like you find on the 6AT and 8AT via XHP. people are just flashing OEM files with OEM tools right now on the DCT. I was speaking about tuning your DME.
General.Massacre
219
57
2009 E92 335i DCT
Agreed and going to say again that the DCT offers no custom tuning,
I have a 2009 N54 DCT E92, and since i owned the car, my LC didnt work, and shifts were tame,
i since researched and recently used WinKFP to load ZSUB 8609092 DCT flash, and the shifts are now alot more aggressive, and alot faster.
I also have my LC back and it works as required.
If anything, i would recommend the 8609092 ZSUB flash.
Reactions: NoGuru
derekgates
740
375
NW FL
derekgates.us
2011 335is
I am confused about this ZSUB; is this different than the US 335is setup? I understand DCT was offered in other countries but I wasn't able to find much information on that ZSUB; it is the "German" DCT setup?
600
Yes it is different. It seems that the ..92 is an evolution based on the non IS DCT cars which not only may be german cars. I don´t know where non IS DCT cars are being sold to.
So lets phrase it the non IS DCT ZSUB. But it has also 5k LC like IS Flash.
IMHO this software version is working really really great!
2,255
805
My humble opinion. The best non M flash for the DCT is actually the z4is. Basically a 1M engine with DCT. Everything else isnt as sharp until you into the M stuff like LMB335is. But then you need to consider final drive changes.
600
So you had the chance to compare both versions in your car? I actually cant imagine any harder shifts :D So i am very interested in your summary.
2,255
805
Its not just about how hard it shifts (for me) and the feeling it gives is affected by many things and so comparing one with another can lead to the wrong conclusion.
From a logical perspective the highest horsepower N54 DCT car from the factory was the z4is.
It was also the quickest 0-400 (do a search of threads where stock cars went to the track)
My suggestion is that you do your own comparison for your own car.
600
I am happy with my ZSUB and don´t see a reason to change. I just thought to ask about your personal opinion but it seems you haven´t compared them yourself.
namsu2430
72
40
Can you guys confirm the ZSUB number. I've seen 8606092 but not 8609092
It's an old table but it's mentioned here n54tech keyap
29544
I want to flash my 335i non IS DCT soon so want to make sure I get the best one.
2,255
805
Every car is different as is every owner. I tried 135is , 335is ended up going back to stock then 135is again.
What do you want to achieve exactly?
namsu2430
72
40
Mostly looking to get the latest software flash. Have read that it reduces the clunkiness when moving off from a stop
JMVELA
67
23
2012 335is
Any ability to increase shift limit beyond 7k for 335is DCT?
I have been told that the only way is upgrading to M3 cluster and all other stuff needed ( there is a thread about this). Then you are able to flash the modern m3-m4 gts trans flash so this way you will have 7,500 rpm rev limit.
Reactions: Asbjorn
scrllock
267
152
2011 335xi
Is there any need to increase the line pressures with adding more clutchpacks? Seems common in the f8x world, but not much info on high-torque n54 dct cars.
