335i AC not engaging after 3-5 minutes (40+ C ambient)
Sava666
176
36
Hello, the issue is that on 335i at 41+C ambient, the AC only engages after 3-5 minutes after a long stay (if stays for more than 8+ hours with AC system pressure reaching equilibrium). After 3-5 minutes everything works fine. Fully vacuumed and refilled with freon using a freon refill machine. SIB 640305.
@carabuser, I am reaching out to you to ask if you have seen any related tables in DME to bypass or fix this issue? )))
Someone please share your wisdom.
