Seems to be little info on the web with respect of the titled error codeswhich i'm struggling to get to the bottom of to get repaired
Firstly Error 307C - Cylinder equalization over Lambda Cylinder 1, to date new plugs, coils, injectors, air intake clean, new intake gaskets and new charge pipe and DV's have been fitted, but code remains.
Code A379 - TCU, error Bluetooth interface error, which is strange since the car comes with a TCU1.5 MOST ECE and therefore (if i'm correct) doesn't not come equipped with Bluetooth anyway?
Finally code A390 - composite output 1 out of tolerance/ Remote supply current out of tolerance.
Any advice or further information on what to look for in terms of finally getting rid of these codes would be greatly appreciated.
