Unlocking the E9X backup camera!
4,332
So I'm not sure how many people know about this, but the iDrive has backup camera software built in, but it was only an option in the European market. The hardware doesn't exist for North American vehicles but the software for it is vestigial, just requires a little emulator box to trick it into thinking the hardware components are there. The hardware required is less than $120, so its quite affordable. I've read this works for CCC and CIC as well as manual and automatic and PDC and no PDC. There may be some coding differences depending on your configuration. If you upgraded your CCC to CIC then its said to be flaky at best. And as always, only attempt this if you know what you're doing or willing to accept the outcome of your work as no guarantees are made. I've purchased the hardware and am going to be doing this shortly, here are the instructions as I've interpreted and organized them.
Hardware you'll need: (I'm currently selling some of this stuff that is extra, contact me in the discussion thread and I can save you some money/hassle)
Software:
  • NCS-EXPERT
So first of all, we will assume you've purchase the camera, emulator box and the PnP splicing harness which should look like this(Image credits to Rotary Rasp):
Just make sure whatever camera you get, has the Micro A/V and power connector, otherwise you'll have issues installing it in the flex tube. To install these pieces, firstly always start by unplugging your battery. You can fry some electronics like your climate control if you accidentally short out some wires.
To give you some visual understanding, the harness is used as an inline extension between the factory wiring and the navigation unit. This means you can splice the emulator into this harness while it is outside of the car for convenience, as well as not have to worry about cutting into the original wiring of the vehicle itself. Here is a photo of someone who spliced into the factory wiring, but at least you'll see where things are supposed to go:
First, you'll need to splice the emulator into the harness. Please see the PDF diagram on how to do that and verify ON YOUR OWN that the instructions are correct! Typos happen!
Take the brown and green (CAN) twisted wire from the emulator, and splice it into pin 11 and 9, respectively. Rotary Rasp has mentioned that sometimes the emulator would lag a few seconds when shifting into reverse and has found that this is because the CAN wires going to the emulator and to the radio are not twisted together tightly. If your video takes a second or two to appear after you select reverse, check your CAN wires.
Do the same with the red and black wires(Power), but splice them into pin 15 and 12, respectively. Lastly, take the white wire from the emulator and attach that to the 12v wire(usually red) on the camera.
Once that is done, you'll need to wire up the camera to the harness. When using the harness, you should be able to connect the RCA + and - into the back of the harness into the correct pin slots using blanks in the plug itself. For North American cars, the RCA + goes into pin 21 and RCA - goes into pin 24.
To test your setup, begin by plugging everything in and when using the harness, you'll have to take the fiber cables on the right side of the plug assembly and pop them into the new harness where it plugs into the CIC unit. Find a temporary grounding point for the camera wire.
Now, before you go through the effort of running all your wires and finding out that it doesn't work and questioning your wiring setup, you should code the car using NCS-EXPERT and see if you get the expected results.
Add the option $3AG to the VO in the CAS and FRM modules.
Enable the feature in the navigation computer (CIC module) by changing these values:
MACRO_PDC
aktiv
MACRO_REARVIEW
aktiv
RVC_CIC
wert_23
MACRO_L6_PARKMENU
aktiv
PDC_DIRECTION
vertikal
Assuming your video feed works, proceed to install the camera.
Remove the trunk liner and replace the existing handle for the new one with the camera and connect to a permanent ground. Fish the wires down one of the support columns underneath the trunk lid.
Be very careful with the flex tube, its a very tight fit, string and soap may help, and puncturing or ripping the tube is very easy.
Route the wire from the trunk to the back of the dash through the rear seat and passenger door seal or behind the center console.
  • Camera wiring diagram Model_Rev1C.pdf
4,332
I'm going to order this and see if it works. I have an 08 with CCC so hopefully it works!
I have an extra emulator box on the way. I'm not going to need it. So the emulator and PnP harness, I've got both of those for sale if anyone wants them and don't want to wait for them to arrive from China. They should arrive shortly. I decided to go with a xcarlink instead, it just costs more.
Oh nice! Did you follow this guide?
I did. I'd add some more emphasis about fishing the wire through the flex boot thing. It's virtually impossible without some kind of lubricant. I used a silicone spray.
Currently the wire is sitting in my trunk. I just have to run it up to the module and plug everything in. I used the extension, too.
4,332
I really hope the extension and wiring diagrams and instructions are accurate for you. I did my best to piece it together from several threads and posts, all without having done it myself. Let me know and I'll be sure to add anything you think is worth sharing!
Things to consider/ things I've learned through the install:
  1. The MOST ring (fiber optic network in the car for audio/video) connections need to be moved from the OEM harness to the extension. You'll have no audio otherwise, and the car will throw lots codes, and also not be able to communicate with a few modules.
  2. If you don't use lubricant to fish the cable through the flex tube in the trunk, you will destroy some of the camera connections. Inside the molded plastic part toward the end of the cable is a circuit board, with pretty weak solder joints. Use a lubricant.
  3. There's a metal pin in the right tail light that looks like it could be a ground. It isn't. I ran a wire from the negative terminal to connect into the camera harness.
Since I destroyed the camera cable, and I couldn't find just the cable on its own, I have a new camera and cable in the mail. I'm really looking forward to re-fishing it all the way to the CIC module again! /s
4,332
That sucks but at least you know what to do. I ordered my camera on Nov 29th and sadly it looks like its barely entering the country:
