535i single turbo
Snertz
64
51
NY
2011 1M
Is Mac solenoid hooked up right, this was my first question. The car doesn't seem to be expecting the boost either, makes me think tune is wrong also. Pretty sure there us a single turbo specific software needed.
I think it does expect something, Target and DME BT looks correct at WOT onset for the map he's on. iirc if the Mac was hooked up wrong it should result in overboost not underboost.
fp_h is tanking hard too, has the HPFP ever been replaced?
Naldo12
42
BMW 535i
No HPFP never been replaced 2 days ago I have a code for the HPFP but it when away
Naldo12
42
BMW 535i
I did use the software single turbo for JB4 back flash with the MHD
4,332
Wastegate spring for 12psi
Mac solenoid is not connected I can't get it to work you think that maybe the issue
If you have a 12 psi spring then you should build boost unless you have connected your Mac solenoid backwards. Do you have open dump or recirculated? You should be able to hear the different exhaust sound if your waste gate is open all the time on open dump tube.
4,332
If he's not getting any boost, and actually has the springs installed "properly" then the gates are being held open.
Upon thinking about the situation, if there is no boost or vacuum source then I can't fathom how his gates would be held open no matter the configuration.
My vote is the springs aren't actually in the waste gate.
Edit: or a huge boost leak
Reactions: Snertz
2,194
Part of it...that is for sure. Might as well fix it while you are troubleshooting as you do need it to drive the car on anything above waste gate spring pressure.
https://www.n54tech.com/forums/showthread.php?t=20406 <--Did you read all of this? Double check your connections and springs.
I would assume the car should run off gate pressure but it sounds like something is not correct and your wastegate(s) are stuck open.
Naldo12
42
BMW 535i
I make boost the problem is when get to 4 psi star popping lean AFR GO TO 20
4,332
I'm no expert but you are WOT from 2600 and make 1 pound of boost at 4000 when most people are 20+ so you have one of these:
Massive massive boost leak
Really bad turbo kit
Waste gates not working correctly
Just because you make boost that doesn't mean your hardware is OK. It just means your setup might experience boost creep even with wide open waste gates. Or your turbo is messed up somehow.
Either way, I would stop driving the car, if the Waste gates aren't working that means that turbine is probably being overspun to death
4,332
4,332
4000 rpm in third gear, no boost. Feel free to fix your fueling issues but this car is going to make waste gate no matter what unless you have one of the issues I mentioned before.
Naldo12
42
BMW 535i
So I have a boost leak but I install the factory TMAP and work fine I have 3.5 from burger motorsports that one is defective
4,332
OK then the Datalog is useless. Do you need to change the scaling for the smaller map sensor? It could be that you are boosting find but your car doesn't see it on the sensor.
Naldo12
42
BMW 535i
When I was using the 3.5 I have it on map 1
Know I have the factory tmap is on map 0
Naldo12
42
BMW 535i
The datalog the I send to you was with 3.5 tmap it was setup at jb4 tmap 1
I will send you one tomorrow with the stock tmap at tmap 0
Naldo12
42
BMW 535i
  • 2020-01-29 08_42_45_Map-1.csv
Snertz
64
51
NY
2011 1M
You need to go into the settings on the JB4 and change the TMAP setting to 3.5bar, otherwise it won't work. This is separate from setting what map the JB4 is running.
Given the age of the car I'd highly consider replacing the HPFP and perhaps the injectors. BMW did put out a recall for both, you might be able to get the dealer to replace them for free.
