535i single turbo
Naldo12
42
BMW 535i
Hi I have 535i single turbo I just finished but at 4 pis the AFR is going to 20 I have a walbro 450 I don't know why JB4 MHD I don't have a port injection I don't know if that the problem some can help me thanks
mfractal
80
27
E90 Sedan LCI 335i FBO MHD E40
this probably should be moved to N55 subforum.
4,332
Additional information
FirmwareInterfaceEngineTMAP_VAvgIgnDWPMethTriggerModeFFMethSafeModeMethAddMethScaleMethPSIVINE85_SetupVFF_Offsetfuel_30fuel_35fuel_40fuel_45fuel_50fuel_55fuel_60fuel_65fuel_70
30/136//2JB4 Android A281E Series - N541.921.85007500600.013568CN55673NONE132505050505050505050
BoostSafetyPID GainAutoShiftRedFuel_OLFUA1st_limiter2nd_limiter3rd_limiterFUDN20_TMAP6CylModeLastSafetyduty_15duty_20duty_25duty_30duty_35duty_40duty_45duty_50duty_55duty_60duty_65duty_70
18.0357586012.015.00.0NONE003505050505050505050505050
4,332
You aren't building any boost. Waste gate DC is 100%
Do you have factory single turbo or after market? It says N54 in your logs. We need more information otherwise we can't help.
Naldo12
42
BMW 535i
Okay 2008 bmw 535i I have S366 Borgwarner turbo 38mm tail Wastegate 2 walbro 450 in tank
2,194
Well you make more boost than an NA engine, so you have that going for you.
The second you make any boost the AFR pegs at 20. Who is tuning your car?
Naldo12
42
BMW 535i
I don't have one I just got the JB4 and MHD back flash
4,332
Surprised you're not making at least gate pressure, hardware issue or major boost leak somewhere?
Is Mac solenoid hooked up right, this was my first question. The car doesn't seem to be expecting the boost either, makes me think tune is wrong also. Pretty sure there us a single turbo specific software needed.
Naldo12
42
BMW 535i
I did download the single turbo version with the MHD
Naldo12
42
BMW 535i
Reactions: TheFixer
2,194
Not that these will fix your issue but any way you can clock that turbo more so it will drain better? That will cause you a future issue most likely. You really want the inlet and drain to be vertical.
You BOV line looks to be too small, and also barely on the tial BOV. I would replace with the correctly sized vacuum line and secure it on all the barbs with a zip tie. You can tap your intake manifold and put a 1/4'' barb on it, small money.
Have you pressure tested the system yet for boost leaks? I doubt this is your issue but worth doing regardless.
I am guessing you plan to run a turbo guard? I would put something on there ASAP.
Reactions: JuniorB
