What tyre pressure for slicks
What tyre pressure for Hoosier 17 275 45
  • 10 or lower
    Votes: 0 0.0%
  • 12
    Votes: 0 0.0%
  • 16
    Votes: 0 0.0%
  • 22
    Votes: 0 0.0%
  • 25 or higher
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Brule
392
463
335i 2007 6spd manual
What tyre pressure have you used at the drags?
I've currently got Hoosier 17 275 40. Around 600hp in a manual 335i
I have read a few drag cars running 7,8,9s second runs running low as 10psi.
I put 20psi in and was going to go down if it was still slippery.
I broke my axle but plan on going back in a few weeks.
What do you think a good starting point for this size tyre?
Cheers
Sshec152
213
118
Aston pa
Are you running a true slick or a radial? You pretty much have to test and see what works, yiu want the highest pressure possible that hooks, so you're more stable on the big end and end uo with a higher et. Usually 20psi is a good starting point
