Weistec Engineering W.3 Turbo upgrade for S55
4,348
The Weistec BMW S55 W.3 Turbo Upgrade unlocks the true potential of the 3.0L Twin Turbo engine. Power gains are substantial, especially in the top end.
The factory turbocharges are disassembled and fully inspected. The compressor cover and center cartridge are then machined to accept our 5-axis CNC machined impeller wheel. Externally, no changes are made to maintain a completely stock appearance. The new impeller wheel supports greater power levels than the factory unit with little to no sacrifice in spool and response. The turbochargers are then reassembled with new seals and fully balanced for smooth operation and OEM service life. All the original oil and coolant lines bolt right up making for a simple install.
  • 580 to 600 HP at the wheels (680 to 720 HP at the engine) depending on fuel and supporting modifications
  • 5 Axis CNC Machined
  • High RPM Balanced for perfection operation
  • Substantial power throughout the RPM range
  • Stock Appearance when installed
  • 100% Bolt on installation
  • All necessary hardware and gaskets are included
$3,499.99
https://weistec.com/w-3-turbo-upgrade-bmw-s55.html
26105
26104
26107
26106
