replacing twins- to lower subframe or remove completely
turbo replacement remove subframe completely or lower
  • lower subframe
    Votes: 7 20.6%
  • remove subframe completely
    Votes: 27 79.4%
  • Total voters
    34
foe516
80
15
so next week i am going to a friends shop to do turbos, oil pan gasket, pulleys, motor mounts, csf radiator. we will be doing on a lift. he thinks we should remove subframe completely. i have read a lot of you guys just drop it. looking for your opinions.
markyb0
106
20
Hampton, VA
2009 335i ST
Id remove it completely. I took off my front turbo once to look at something without taking the subframe out and it just made it 100x harder. Remove it and everything will be out of your way and much easier to work on. Pretty sure you have too drop the subframe anyway to do the oil pan gasket.
N54QC
127
67
07 E90 335i
I just lowered mine to do the turbos and pan gasket. Did it in a storage unit on jacks so removing it was out of the question.
Milan
413
241
jebi se
your mom
The extra time it takes to remove the subframe is easily offset by the time savings of installing the new turbos without the subframe in the way. Maybe with a design like MMP it wouldn't be too bad
2,198
I lowered it when I did my single install. It honestly does not take much time to do. I can't imagine doing the install of a single or stock frame without doing so. I mean I am sure it could be done but is it worth the hassle?
buster84
240
91
335 bmw xdrive
If the shop is doing it have them take it off to make it easier and faster for them. If your doing it yourself its upto you to decided which you prefer.
On my xi I lowered my subframe and replaced my turbos (went from gc 1.0 to 2.0) so my experience might be a tad different since I could remove it easier by splitting the manifold; however, I had to install the manifold to the turbo before reinstalling so it was reinstalled no different than a stock turbo. I never removed the front axle, or the waterpump/thermostat. If you have the time and small hands it's very doable.
The way I look at it is this. If you want to remove the least amount of parts to save you self the trouble of losing bolts/breaking anything or not knowing where things go back then I'd suggest dropping the subframe and then if you hate the smaller working area you will always have the option to fully drop it. Just make sure you get good torque wrenches that range from 5nm to 100nm to retorque all the bolts back to OEM specs.
1,285
779
I voted to remove it completely. It's not that many bolts, only takes a few minutes to do, and give you unfettered access to everything. Why make life difficult by leaving it in place?
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
I did my single turbo install on jack stands in a parking space with the subframe in. Sucked donkey dick but is definitely doable.
If you have a lift and are also doing OPG, etc, just remove the subframe so you don't hate yourself lol
3,642
... or you can do it like my buddy @Asbjorn 's folks in China ... they don't fool around.
(from Asbjørn's build thread)
chadillac2000
233
255
NC
2008 BMW 135i
I'd suggest not being in a hurry with an install of this magnitude and just remove it. You'll spend more time working around it then you'll have invested in just taking it off. Next time I have to go back in for a turbo install, I'll probably just pull the engine/trans out the front and assemble everything on a stand.
Reactions: Jeffman and Torgus
buster84
240
91
335 bmw xdrive
Not true for everyone. If your smaller with smaller hands you have more room than someone that's alot bigger overall. Space is relative to your size so removing the subframe is just another way to make it easier for certain people. It just depends on your comfort level. The longest part of the turbo install is figuring out where what goes where and what torque you need to apply to what bolt and what sequences are needing for reinstalling it without wasting time removing something ecusse you forgot something. I had this problem with my right engine mount. Installed everything and I forgot about the engine mount dumb moment but it does happen
chadillac2000
233
255
NC
2008 BMW 135i
More power to you my friend. I'm 5 foot 10 inches, 150 pounds so not big by any stretch of the imagination. What's another hour of labor when you're doing all that work yourself though? It doesn't take any specialty tools or know-how, and doesn't mess with any alignment settings, yet frees up all the room in the world. It was worth it in my eyes just for the ease of reinstalling the water pump and all hoses. Not to mention the oil pan gasket, which should probably be replaced while you're in there.
This is with a large DSLR camera and my head fully poked up in the engine bay. Look at all that room!
buster84
240
91
335 bmw xdrive
I'm not arguing against it I'm just saying that having more room doesnt gaurntee a faster repair especially if your new and by yourself.
I did it on my x-drive and left on alot of stuff on the car and still finished the install in a timely manner. It was fairly quick and the longest part for me that took all day was relifting the subframe while alligning it all by myself. I had go get crafty and out together some wood and jacked it up that way and got it all together.
To each there owns, but it's always good to hear from people (like you) who have actually done the swap and there methods and car model (x-drive or rwd).
I didnt take many photos but here is one that shows how much I left on when doing the swap. I wished I snapped a photo of the amount of free space i had but I apparently didnt. I'm 5'10 155lbs and felt like I had plenty of room.
Here's some photos of the turbos installed and everything I left on.
silverstreak18
129
67
Charlotte, NC
2016 M3
View attachment 13317 View attachment 13318 View attachment 13319
You have a decent amount of room when you lower the subframe, I still find it easier to swing it out of the way. It takes maybe 10 more minutes to do so. Judging from the corrosion on those control arm bolts though I'd guess you're up north, so I probably wouldn't want to take apart anything I didn't absolutely have to either.
buster84
240
91
335 bmw xdrive
I'm actually in FL, but I purchased the car recently from someone who lived where it showed alot and had salt all over the roads.
