Who are you thinking of building it?
I'm not using DI anymore, so when I blow up mine my options are a built n54 wity plugged DI ports (same as now although its otherwise a stock block), built n54/n52 mut, built n52, LS swap, dump the platform. Vac do a billet s54 which I guess I could throw in the mix.
Galloway looks like there pretty capable on the machining front but I haven't got first hand experience with local machinig/building so keen to follow how that works out for you.
im not sure who im going to get to do it yet. have asked a few people and had a few different recommendations. head torque seemed to be the most recommended local place for headwork but still undecided for the bottom end.
i plan to go stand alone ecu and PI only before putting a built motor in but i guess we'll just have to see how long the stock one lasts.
-fully built th400 reverse pattern, manual valve body with a trans brake and dump. (Rated for 2000hp) built by all fast torque converter
- b and m ratchet shifter
- custom torque converter 5000-5500rpm stall 9.5 inch converter
- built Ford 8.8 inch rear end
- trutrack dif centre with 3.73 rear gears and 31 spline full billet out law axles from g force
- chromoly drive shaft (waiting to fit trans for exact specs required but this is only thing left to purchase)
- stage 4 kit from fuel it it with both pumps upgraded to walbro 525 and port injection injectors upgraded to 950cc, fuel reg, return kit, upgraded lines etc. port injection run off split second controller.
- billet forward facing intake manifold
- full custom single turbo kit utilising a pulsar 7375 (g-42 -1200 rep)
- turbosmart gen v 60mm powergate
- 4 inch straight pipe exhaust for street but removable and able to be dumped out the fender for race
- line lock kit
- weld pro star 15x10
- Mickey Thompson et street R 275/50/15 (will attempt to fit a pro radial and go to a shorter rear gear once ive gone through these tyres)
- oil catch can
- stand alone 57l fuel cell
- 27mm stiffer rear sway bar
- Viking drag shocks all round
- upgraded oil cooler
- upgraded radiator
- upgraded mishimoto trans cooler and fan
- PR coil packs upgrade
- 3.5 bar tmap sensor
- small brake kit on the rear assembled using oem bmw parts
- heads been freshly carbon cleaned
- ARP head studs from MMP with 50% more thread engagement
- bare metal stripped interior except dash
- kirkey pro street driver seats
- kirkey alloy passenger seat
- single cross bar to mount seats
- VRSF 7.5 inch race intercooler
- solid aluminium dif bushings
- solid aluminium subframe bushings
- upgraded pcv
- ugraded front rotors for stock brakes
- braided brake lines
- aeroflow turbo blanket
above is the build list so far/currently being done. unsure why my other thread hasnt posted yet.
