n54 fuel drop
oVeRdOsE
75
27
the e89 dont have a lpfp pressure sensor iirc, you dont have any log on it. hard to tell if the hpfp is the issue or the lpfp.
you have a major hpfp drop.
in my case the lpfp was the issue .
however, I was pushing 480whp on a xi with 750 psi on the hpfp, and you're at 950 psi.
safe limit is around 1200psi.
I drilled the fuel rail few weeks ago and redo the line on the venturi valve and now holding 1200psi at wot.
