Mystery Misfire!
tommyhondros
62
14
e92 335xi coupe
Hello, I am having a constant misfire in cylinder 1 after recently changing to NGK 95770 at .020 now .022 and Delphi coils. In the last 2 weeks I have walnut blasted, new valve cover and gasket, new hpfp, moved injectors (all index 12) from 1&2 to 3&4 new decouplers/seals and coded. I've reset adaptations with inpa. Changed from e60 custom tune to MHD OTS pump. Consistent misfire cylinder 1 and lean. O2s/LPFP sensor/Wiring is all I can think of. I did a compression test and compression was good. Someone please help I will attach some logs. Thanks!
http://datazap.me/u/tomhondros/no-misfire
http://datazap.me/u/tomhondros/misfired
http://datazap.me/u/tomhondros/didnt-misfire-was-pulsing
4,348
Have you tried a .018 gap?
Reactions: 1and1
1and1
65
35
Tally, FL
As I read your OP, all was fine until you swapped in new plugs and coils. You then got consistent misfires in the no.1 cylinder- that about right?
You then list troubleshooting for everything /but/ plugs & cp's, aside from making the plug gap larger so the cp's would have to work even harder.
I'd strongly encourage trying a smaller gap first like suggested above, then,if the symptom persists, swapping the no.1 & no.3 cp to see if the problem follows the cp.
Not much to go on here, but my money is on the Delphi CP being weak.
Nov 14, 2016
651
262
North Wilkesboro
Correct, with all the things considered. The first things to check when it comes to a missfires is the most critical pieces to the combustion cycle.
We all know what a missfires is but, there's only a select amount of elements that could be to blame in the process.
Power and fueling are the main to ingredients to make this process work. If your fuel pressure across low and high pressure systems are good then, check the injectors. Common signs of a failing injector is either
A) pull the spark plugs and if they smell like gas or you receive rough starts then you found a problem! (This also lets you see if the spark plugs are okay anyways)
B) in logs you'll notice trends across one bank or both banks that the AFR is deviating from Target either during spool or during high RPM. (Timing corrections may also follow this trend and, you can resolve those possibly as well)
While you have the spark plugs out check the inside of the coilpacks for and debris or corrosion.
If all else fails as mentioned swap the CPs around and see if the trend follows.
Once all of these things are done then you still have some options of things to go trough from bad oil filters causing VANOS issues to possible mosefets failure.
Reactions: 1and1
tommyhondros
62
14
e92 335xi coupe
Got my mosfets tested today all good. Will try the .018 gap. I have swapped coils and plugs around so many times it doesn't follow as well as injectors. I will try the gap if not I'm gonna try a buddys spark plug set. Reason I increased gap is because I went from e60 to pump so figured the smaller gap wasn't necessary.
Nov 14, 2016
651
262
North Wilkesboro
Does all of the wiring and connections look good for the cylinders giving you issues?
tommyhondros
62
14
e92 335xi coupe
Yeah I had to reground 1&2 cylinder ground with a ring connector but got it down. The car runs so smooth under 4k I can see the plugs being bad even tho there 3k miles ago I gapped them so many different times could've damaged the electrodes
Nov 14, 2016
651
262
North Wilkesboro
Be very careful when doing that because, there is the possibility that over time with all the heat and pressure that is on them during heavy load that if the physical strength is weakened it could fail or ultimately brake.
Do you have your old spark plugs still? You could swap those back in and, see what happens.
tommyhondros
62
14
e92 335xi coupe
Understood will constantly check on it. Do not have the old plugs or would've tried already. I was running Bosch and they were great I did a bunch of maintenance prepping for turbo upgrade and the NGKs might just not mix..
nders
Nov 14, 2016
651
262
North Wilkesboro
nders
Which NGKs do you have? I have 5992s on my personal car (Gapped to .020) Bosch Coils though.. I've never heard anything horrible about Delphi coils so, possibly just a bad set? No other error messages or anything?
tommyhondros
62
14
e92 335xi coupe
Also have 5992s were gapped at .020 and misfiring on 20ish psi on stockers. I have even put a tested working coil in 1 and still misfires there. It is constantly 1 maybe because its the first cylinder but I will try regapping them to .018
R.G.
668
328
Henderson, NV
E92 335, F10 M5
My car seemed to dislike the NGKs and were always problematic. I've been running Brisk QR12LS plugs and have loved them.
ST 21psi ~10k miles .022 E50 on the ones pictured. They're expensive unfortunately and require a different ultra thin socket
tommyhondros
62
14
e92 335xi coupe
Good find Will definitely look into it as I am going ST shortly
Bmwfixerguy1
875
292
07 335i MT
Check dme connection.. I've had a few now where water gets I to the ebox from an improperly installed ebox cover.. We are in and out so much with the advent of the jb4 that they get I stalled poorly and get water in them.. Bam horribly corroded dme connections and both of them were misfires
tommyhondros
62
14
e92 335xi coupe
Pulled and opened it yesterday all looked well ordered a set of bosch plugs ran those b4 with no misfire as soon as I switched misfire. Hoping it fixes my issue
d
08_335i
371
215
2008 ST 335i
d
I'm not sure why, but on stock turbos my car misfired like crazy above 4k rpms with the NGK's, Bosch's ran like champs. But now with my ST it absolutely loves the NGK's.
tommyhondros
62
14
e92 335xi coupe
Same here I get the new plugs in a day or so if that fixes the issue will be kinda mad of all the time/money I've put in but atleast everything maintenance wise is covered.
