Motiv Reflex - N54 big power
JMVELA
67
23
2012 335is
Hi! Who can guide me to verify if I have all set correctly on my reflex? I am using Aux Output to turn on my meth pump since I run meth port injection. The other thing I have connected is the pressure sensor from Motiv to monitor the Meth port injection rail pressure. I also have a 3.5 AEM map sensor connected but I have an external boost controller to control boost.
I don't mind to pay for this service, but definitely I need some guidance. And yes, I have tried on multiple occasions to contact the seller (Motiv - Jake and Chris) and no response. Have been waiting for an answer for a week and nothing. Your help would be appreciated. If you prefer to answer through private message, please do so.
Thanks for the help
678
I am in the same boat :D Hope somebody will shine in to help. My serial number of the reflex is 812 i think. I hope a few are in here :D
ckh091020
33
Did you wire the Flexfuel sensor to your Reflex? if so, how does it communicate with the DME and MHD? is it through CAN bus or just normal Analog input in the DME? For your Meth activation, is it just reading the AEM sensor within one system or you are getting data from DME ( CAN BUS)?
