Misfires on cylinder 6 at high boost... weak hpfp ?
twinturbos
291
79
E92 335i MT
Hi,
It seems like this is getting worse as I am now only able to boost at wastegate pressure without misfires. 17psi and 20psi misfires on cylinder 6.
I am thinking I have a weak and dying HPFP.
car is running the docrace single kit 6266BB, fuelit stage 2 lpfp, 94 octane.
Injectors, coilpacks, barely have 3000 miles, spark plugs have probably less than 1000 miles. Gapped to .022 I believe.
Here's a log today targeting 17psi:
noorj
140
104
Detroit, MI
'07 E90 335i
that first log looks really rough. who is tuning it? how old are your o2 sensors? huge bank to bank deviation like that is either injectors or o2 sensors, and if you have relatively new injectors I would guess o2's. The second log shows multiple instances of the o2's reading <10, which is an implausible reading
Reactions: twinturbos
twinturbos
291
79
E92 335i MT
o2 sensors also have around 3000 miles. I am running JB4+MHD single turbo it is not properly(custom) tuned yet as I was waiting to get everything and trying to make sure it runs properly with everything.
First log I floored it and it misfired as soon as i went into boost :fearscream: and set a CEL.
Bnks334
530
344
Hi,
Rail pressure is tanking at boost onset... You're down to 1000psi. Reduce boost at this rpm range or find a way to get more fuel volume at low rpm.
I've been building and trouble shooting my mates single turbo setup for a while now and the biggest issue was the jb4.
Get your self a boost box and get yourself a custom tuner .
If you insist of using the jb4 talk to @trebila he is the best at these.
I would also get a shotgun kit as I fitted around 15 of these kits with no issues what so ever to help you with your fuel pressures but a double barrel kit
will see you never ever run out of fuel pressure, you will max out your stft's before you run out of pressure.
The missfire is due to something not set correctly in your tune, you need a custom tune.
twinturbos
291
79
E92 335i MT
Thanks for your reply. The car was fine for the past 5000 miles running the exact same setup before this started to happen... once then 2 weeks later again and another couple of days later started happening every single day. I'm only running pump gas, waiting to figure this out before starting to spray meth... not planning on running E85 so doubt I'll need a shotgun kit. I'm just wondering if the hpfp is starting to be weak.
twinturbos
291
79
E92 335i MT
Auto trans?
Manual
Little update, it seems water was dripping in that area from the windshield. Noticed a bit of rust on the coilpack and its barely a month old. Tried another coilpack and it still misfires at 20psi. I guess I will check the plug when I have a moment. Otherwise hoping I dont need an injector or an engine.
Cheezy
611
225
Toledo Ohio
Manual
It might be the ol' dual mass flywheel issue. Google it for more information. If it were auto I'd have more advice. We've got a handful of people with cyl6 misfires we're trying to solve.
works
42
15
135i
I had a misfire at 6000-6500rpm that, after changing injectors (9->12, that was necessary regardless), plugs and coils, turned out the be the DMFW. Which I changed to M-factory SMFW and all my misfires went away. And as a bonus I got a driveline directness with the new zeroed out throttle filtration values that I never thought would be possible on this platform.
I'm completely fine using the 335is/550i springless clutch with the springless SMFW, it requires some concentration when driving. But YMMV.
twinturbos
291
79
E92 335i MT
Thanks guys, I'm running the xclutch twin disk ceramic clutch so the flywheel shouldn't be an issue. Ran a compression test on it today everything is fine compression wise. Guess I gotta keep looking.
works
42
15
135i
That kit comes with a flywheel as well? [edit] Google is my friend and yes, it does come with a SMFW.
twinturbos
291
79
E92 335i MT
Did a compression test. All is good. Also replaced the HPFP with a new one. Still misfires on cyl 6. I guess at this point I either need an ignition upgrade or an injector (has like... 3000-4000 miles on it :angry:)
Bnks334
530
344
Why is AFR 2 so rich right at the point the misfire occurs? AFR 12.9:1 AFR2 10.9:1. TRIMS 2 is at 20%.
Edit: now that I think about it, AFR2 going rich could possibly be an "effect" from the misfires on bank 2 and not the "cause" itself. Then again, trims on bank 2 are high throughout the whole pull... so maybe something to look at there.
twinturbos
291
79
E92 335i MT
Possible leaky injector ?
Bnks334
530
344
High trims means fuel is being added. Leaky injectors usually means rich condition at idle and negative fuel trims. Hence the white smoke out the exhaust when it gets bad.
Can you swap O2 sensors on N54? see if the condition moves to the other bank as the O2 could be going bad like the other poster suggested. It's a shame JB4 pegs out at AFR 20. With MHD you can usually spot a leaky injector by looking at AFR on decel to see if it settles to 235.
