Misfire Troubleshooting Assist
I am Jacks N54
88
Ventura, CA
e90 335i
Misfires on cylinder 5 have popped up on my 07 e90.
FBO, minus inlets and exhaust​
Stage 1 Walbro 450 pump​
MHD stage 2+ and e50 for the past 3-4 months​
As soon as the misfires started, I replaced #5 NGK-97506 and upgraded all coils to new Eldors. While I was in there, I noticed an abnormal amount of oil that I traced back to the Crankcase Vent Hose. Pulled it off and found my o-ring was pinched, which was leaking oil right above cylinder 5 and 6. Replaced the o-ring, cleaned the leak areas, got everything back together and cleared the 29D1 code.
Unfortunately, the misfires are still there. I just swapped #5 and #6 coil and plugs, and can tell the misfire is still there, it just hasn't gone active yet. Here's a video of the rough idle.
Searching has led me to injectors. Given that mine are original Index 1's :grimacing: it seems likely, but I don't want to jump the gun like I tend to do with diagnosis given the cost involved.
Cruise Around the Block Log (after clearing codes):
Any help with diagnosis is greatly appreciated šŸ»
I am Jacks N54
88
Ventura, CA
e90 335i
Be sure to renew the teflon seal and decoupler on other injector, if you are just going to replace the faulty one.
I replaced the seal and the decoupler on the replacement injector, but do I need to replace both on the injector I swapped from #5 to #6? I did get the PR injector tool, so the seals were compressed before installing.
BloodyZ4
56
37
Germany
Z4 35i DCT
Well BMW recommends replacing them, as they are one use only.
Personally I wouldn't risk it. If the decoupler isn't perfect the injector starts to oscilate in the head and will oval it out.
Since your doing the labour yourself I would just do them for peace of mind, it's only a couple of bucks, why risk it?
