AJN55
Datalog Looking for analysis on this log. 2011 335i. I’m totally new to data logging so input is appreciated
dinocrest
21
Looks a little hot, What was the outside temp when this log was done? The stock intercooler Is a very poor design and will cause the car too quickly heat-soak after even just 1 pull.
AJN55
Minneapolis
2011 335i xDrive
It was probably around 85-90 degrees that day. And it’s generally pretty humid in Minnesota too. The stock intercooler is definitely not very efficient!
Aug 18, 2018
10
2012 335is E92 DCT
Log looks good, IAT is very good if the ambient temps were 85-90. Load Req vs Actual is spot on. Crank timing is up in the 14+ degrees, must pull hard eh? Boost is holding to redline. The log indicates a nice powerband, enjoy!
AJN55
Minneapolis
2011 335i xDrive
That’s good to hear, thanks for taking a look at this! I just logged a WOT pull today with my catless downpipe installed, if you want to check that one out and give me your input I would really appreciate it!
Aug 18, 2018
10
2012 335is E92 DCT
It should be the most recent post on my profile. It’s titled “WOT pull 60-100”
Logs look good, nothing out of place...EXCEPT, it looks like you forgot to completely turn off the DSC/Traction Control.
