How to Properly Refill the ZF 6HP19/21 Transmission
AUbeast86
298
New Market, AL
335i e92 6MT
Hey guys, I've been seeing some people reporting some issues lately resulting from not properly filling the transmission after rebuilds, upgrades and/or maintenance. These issues range from poor shift quality to failed shifts that have ultimately resulted in trans limp mode.
It's also extremely important to reset and relearn the adaptations every time the ATF is changed so I'm working on finishing that DIY for you guys as well.
The attached DIY uses several sources referenced from ZF literature that I've modified for clarity and comprehensiveness.
I'm happy to answer any questions you guys have regarding this procedure.
  • PD ATF Fill Procedure.pdf
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Jason,
I read in one of the docs I found that the car should be in N when filling. I suggest everyone check their fluid again after a 100 miles. Managed to get another .5 liter in. Use the fluid Jason recommends, those other brands will cause problems, ask me how I know.
AUbeast86
298
New Market, AL
335i e92 6MT
Jason,
Excellent point about checking the fluid level again after 100 miles. We were able to get an additional .5L in after a few miles as well.
I also have seen the other instructions call for the trans to be in N when filling. I've done it both ways with the same result so we went with P in our instructions for safety purposes.
Hey Jason,
How important is it to have the AC turned on when doing the ATF fill? I have never heard of this requirement from shops, youtube diy videos, or even the Bentley manuals. What does the AC do when it is turned on while filling the ATF?
VT
AUbeast86
298
New Market, AL
335i e92 6MT
Hey Jason,
VT
Every piece of ZF literature I've ever read regarding this procedure included turning the AC on. It puts more load on the engine which in turn pulls more ATF through the system so you get a better fill. Not doing so could cause your ATF level to be lower than optimal.
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Guys, have your shit ready to get under the car and refill before starting it up. The window where the trans temp is ideal comes and goes QUICK. It takes hours for the fluid temp to settle back down if the window passes, even in cooler weather.
Reactions: AUbeast86
cityazndan
108
14
2016 340i xDrive
So this gets the full (11-12qt?) of ATF out instead of the traditional 6-7L trans pan service, correct?
BOosted 335i
315
104
New Jersey
E90 BMW 335i
what are you guys using for ATF Fluid in your 335 auto trans.i have a 2008 335 e90 so not sure if the autos are different from the next.Reason why im asking is i have Redline ATF D4 in my car.when my warranty was up i drained,filled with redline,drove around drained again so it would mix then filled up again so i can get most of the old fluid out.Im just wondering if i should keep the Redline in or switch to something else.Now im running a single turbo and whatever i can do to help the longevity of my trans.
I recommend zf. Fluid for non-modified trannies.
But if ypu have redline on there already ot will be super expensive to completely flush out the redline. Stick with that until it goes kaputt.
1,929
664
What else should be changed besides fluid and pan/ filter i have read their are 4 seals and mech sleeve that should be changed some say to change solenoid as well at 60 to 100k and is their a kit that just has everything needed?
I just did that job for a client.
1. four seals tubeshaped
2. one rectangular seal
3. new set of solenoids on valve body
4. new filter/pan
5. new ATF
6. reset adaptations
7. ZF drive programming procedure
1,929
664
4. new filter/pan
5. new ATF
Where are you located?
I am based in Houston.
For that service I charge $500 labor. Client is responsible for proper ATF 10 liters, solenoid kit (eshift or m shift), all seals and o rings, pan filter, solenoid foam strip separator, and mechatronic external connector seal.
4,348
Skip to 4:50
Also, I want to add that you should not follow step A if you intend to simply top off your fluid. When the engine is not running all the fluid drains back down to the bottom and it will start pour out on your garage floor.
scrllock
267
153
2011 335xi
Just had my trans fluid + filter/pan done and was told specifically NOT to reset adaptations. The prescribed ZF learning procedure is pretty difficult to do unless you've got a lot of open road or a dyno handy, too.
xHP recommends the same: https://www.facebook.com/xhpflashto...-controlsince-the-launch-of/1923761651273188/
My understanding is that it should only be done when hardware is being changed out, not just for fluid changes. I'm sure there are people doing it regularly, but surprised to see contradicting info from PD. Curious what their reasoning is.
1,929
664
No you want to do it with any change including fluid however it is better to not do it than to do it and not do proper relearn as you can damage transmission. The transmission will learn on its own gradually it just will take longer. Also If doing fluid and mech sleeve as maintenance it's not as big a deal if doing it because their was an issue than its wiser to reset adaptations as it's more likely to have a drastic change in shift times or pressure.
Reactions: matreyia
