How to input external sensor data into MHD datalogs?
4,348
Years ago I had some PLX modules and gauges to get IAT's for example but what about today? Is there a good solution for getting external sensor data into a single log? I wanted the ease of not worrying about matching up timelines. One thing I've been wanting to measure is crank case pressures.
Asbjorn
856
605
European, based in China
Z4 N54 DCT
I believe matching up timelines is the only way.
When I make videos with gauges that take logs from both AIM and MHD data, I typically skip the log consolidation part and just adjust the offset in racerender. It is a bit faster, and you don't need to worry about differences in log resolution.
Like in below video, I combined logs from MHD, AIM and an oil pressure log I had manually entered using a video taken of the gauge installed in the car. :grinning:
