Honing ALUSIL Blocks
1,046
Anyone here have any experience honing a Alusil Block. From my research it is possible, with using a AN-30 compound and felt pads. Just need to get the slighest scratches out of a cylinder and prep the block for new rings?
881
You mean honing the LDS coating on the walls coated onto the Alusil of a b58 block?
Did you break a piston? Or just proactively building your motor😍😍😍
678
Here is what pro engine builder ChatGPT has to say:
If you’re just dealing with very light scratches in an Alusil bore and want to freshen it up in a DIY garage setup, you can skip the heavy industrial gear and go with a light reconditioning process focused on cleaning and re-exposing the silicon. Here's what you'd need:
✅ Light DIY Alusil Reconditioning Kit (Garage-Friendly)
🧰 Tools
  • Flex-Hone for Alusil (ball hone, fine grit ~240–320)
    • Brand: BRM (Brush Research Manufacturing)
    • Get one that matches your cylinder bore diameter
  • Variable-Speed Drill
    • Must be able to run at low RPM (~300–500)
  • Torque Plate (optional but good)
    • If you want to be precise
🧪 Chemicals & Supplies
  • Alusil-compatible honing oil
    • Light mineral oil or ATF works in a pinch
  • Alusil Etching Paste or Lapping Compound (optional)
    • To help bring out silicon particles
    • e.g., fine aluminum oxide paste or Glyptal style paste
  • Brake Cleaner / Acetone
    • For degreasing
  • Hot Soapy Water
    • Final wash to remove grit and particles
  • Lint-free cloths and paper towels
📏 Inspection Gear
  • Visual Inspection Light or Bore Scope
  • Dial Bore Gauge (only if you're checking geometry)
🛠️ Process (Short Version)
  1. Clean the bore with degreaser and inspect scratches.
  2. Light Flex-Hone pass (10–20 strokes per cylinder, low RPM, plenty of oil).
  3. Optional: Apply etching paste to expose silicon crystals.
  4. Brush finish if needed (hand brushing with Scotch-Brite or bore brush).
  5. Final Clean with hot soapy water → brake cleaner → dry with lint-free towel.
  6. Inspect surface – should have visible silicon and a light crosshatch.
⚠️ What Not to Do​
  • Don’t use conventional stones or aggressive abrasives.
  • Don’t remove too much material — it’s easy to go too far.
  • Don’t leave grit or residue behind — it’ll ruin your rebuild.
Want a shopping list with product links or part numbers?
1,046
MANNN boys boys B58 is still running strong. This is for the X6m my dad bought. I assume it has a cracked piston ring. BADDD leakdown, slight scoring on the cylinder walls. Just Wanted to make sure the scoring out, before pulling the engine out.
881
Glad you're b58 is running strong😉
Reactions: SLOWESTN54
