B58 edit target boost
idm2
hi im tried self edit backend map and try add more boost
( pure 800 ) my target is 23 psi but its not over 21.5 psi :( try edit load set to 220 but the req on log stuck on 200 only ( like backend )
tried set more torque req its not help
can help
  • b58_98.bin
  • 00003076501D02_B58F.xdf
  • b58_98.csv
Nick380
40
21
CA
No experience here, but looking at a few tables. I did notice this:
Looks like if EKP maximum value is hit, it will lock load to 200...maybe that's your cause? Fuel limitation on the low pressure side? Also be careful, I see some serious timing pulls from cylinder 1 almost 7 degrees! She's not too happy. Good luck!
dannytactic
Not checked your logs, but it could be that the gearbox is limiting perhaps torque, if you have not touched the torque to load map, if you altered it but not adjusted the tcu it may limit there, i would check to tune tcu so you can exclude it from your list of possible limiting factors, perhaps you could try to fool the can signal by putting th can for gearbox switch to 0 if remember correctly this will bypass the torque limits in tcu but clutch clamp pressure may be calculcated wrongly of this
