DME Mosfet to pin continuity
TooMuckinFuch
I know the source legs of the transistors all go to the same header pin for the harness but is the other leg (gate, I guess?) of the transistors supposed to have continuity to header pins? Two of mine do and four don't (as far as I can tell).
TooMuckinFuch
Thanks for the reply. Anyone else have their DMEs pulled at the moment? I can't find a straight forward pinout of the ecu headers to save my life. Coming from 2JZ and Nissan platforms, I've been spoiled. Lol
V8bait
505
785
Texas
It's around, can't find it right now but it's out there. I've posted it a few times.
TooMuckinFuch
Update: my mosfets came in today and it runs fine now.
Conclusion: not sure if continuity proves anything between gate and header pins. Didn't seem to matter or prevent the typical mosfet fix.
Reactions: screaminfast
V8bait
505
785
Texas
Copy/paste here-
Plug connector overview
Number X-pin, colour Description
X60001 26-pin, grey Component connector DME control unit
X60002 26-pin, black Component connector DME control unit
X60003 6-pin, black Component connector DME control unit
X60004 6-pin, black Component connector DME control unit
X60005 44-pin, black Component connector DME control unit
X60006 12-pin, black Component connector DME control unit
X60007 26-pin, natural Component connector DME control unit
Pin assignments at plug connector X60001
Pin Type Description /Signal type Connection /Measuring notes
1 E/A Signal PT-CAN low Powertrain CAN-bus
2 E Start signal Car access system
3 E/A BSD signal Battery sensor
4 E Brake light signal Brake light switch
5 A Signal, exhaust flap Exhaust flap
6 E Signal Temperature sensor at radiator outlet Temperature sensor at radiator outlet
7 E Signal Accelerator pedal module Accelerator pedal module
8 A Signal Electric fan Electric fan
9 A Activation Radiator shutter drive unit
10 M Ground Accelerator pedal module Accelerator pedal module
11 A Supply Accelerator pedal module Accelerator pedal module
12 -- Not used
13 A Activation Secondary air pump relay Secondary air pump relay
14 E/A Signal PT-CAN high Powertrain CAN-bus
15 E Signal, electronic vehicle immobilizer Car access system
16 E Brake light test signal Brake light switch
17 E Signal, rear right wheel speed Connector X10186 (rear right wheel speed)
18 E Signal, clutch switch Clutch switch module
19 E Signal Temperature sensor at radiator outlet Temperature sensor at radiator outlet
20 E Signal Accelerator pedal module Accelerator pedal module
21 E/A TD signal Connector TD signal
22 E Supply, terminal 15 Car access system
23 M Ground Accelerator pedal module Accelerator pedal module
24 A Supply Accelerator pedal module Accelerator pedal module
25 E USA Signal Secondary air - hot-film air-mass meter Secondary air - hot-film air-mass meter
26 A Signal, E-box fan E-box fan
Pin assignments at plug connector X60002
1 E Wake-up signal, terminal 15 Connector, terminal 15 wake-up
2 -- Not used
3 -- Not used
4 -- Not used
5 E Signal, oxygen sensor Oxygen sensor 2 before catalytic converter
6 E Signal, oxygen sensor Oxygen sensor before catalytic converter
7 E Signal, oxygen sensor Oxygen sensor 2 before catalytic converter
8 E Signal, oxygen sensor Oxygen sensor before catalytic converter
9 E Signal, oxygen sensor Oxygen sensor 2 before catalytic converter
10 M Ground Oxygen sensor before catalytic converter Oxygen sensor before catalytic converter
11 M Ground Oxygen sensor 2 before catalytic converter Oxygen sensor 2 before catalytic converter
12 E Signal, oxygen sensor heating Oxygen sensor before catalytic converter
13 E Signal, oxygen sensor heating Oxygen sensor 2 before catalytic converter
14 -- Not used
15 -- Not used
16 E USA Signal, fuel tank leak diagnosis pump Diagnostic module for fuel tank leakage
17 E USA Signal, fuel tank leak diagnosis heating Diagnostic module for fuel tank leakage
18 E Signal, oxygen sensor Oxygen sensor before catalytic converter
19 E Signal, oxygen sensor Oxygen sensor 2 after catalytic converter
20 E Signal, oxygen sensor Oxygen sensor after catalytic converter
21 -- Not used
22 E USA Signal, fuel tank leak diagnosis valve Diagnostic module for fuel tank leakage
23 M Ground Oxygen sensor after catalytic converter Oxygen sensor after catalytic converter
24 M Ground Oxygen sensor 2 after catalytic converter Oxygen sensor 2 after catalytic converter
25 E Signal, oxygen sensor Oxygen sensor 2 after catalytic converter
26 E Signal, oxygen sensor Oxygen sensor after catalytic converter
Pin assignments at plug connector X60003
1 E Supply, terminal 30 Fuse F50 from 03_2007 up to 2007_08
1 E Supply, terminal 30 Fuse F4 from 2007_09
1 E Supply, terminal 30 B+ potential distributor up to 03_2007
2 E Supply, terminal 87 Fuse F78 from 03_2007 up to 2007_08
2 E Supply, terminal 87 Fuse F37 from 2007_09
2 E Supply, terminal 87 Fuse F02 up to 03_2007
3 E Supply, terminal 87 Fuse F78 from 03_2007 up to 2007_08
3 E Supply, terminal 87 Fuse F02 up to 03_2007
3 E Supply, terminal 87 from 2007_09
4 M Ground Ground point
5 M Ground Ground point
6 M Ground Ground point
Pin assignments at plug connector X60004
1 A Activation Ignition coil, cylinder 1
2 A Activation Ignition coil, cylinder 2
3 A Activation Ignition coil, cylinder 3
4 A Activation Ignition coil, cylinder 4
5 A Activation Ignition coil, cylinder 5
6 A Activation Ignition coil, cylinder 6
Pin assignments at plug connector X60005
1 -- Not used
2 -- Not used
3 A Activation Volume control valve
4 -- Not used
5 -- Not used
6 -- Not used
7 M Ground Low pressure fuel sensor Low pressure fuel sensor
8 A Supply Low pressure fuel sensor Low pressure fuel sensor
9 M Ground Intake air temperature/boost pressure sensor Intake air temperature/boost pressure sensor
10 E Signal Intake air temperature/boost pressure sensor Intake air temperature/boost pressure sensor
11 A Supply Intake air temperature/boost pressure sensor Intake air temperature/boost pressure sensor
12 -- Not used
13 A Activation DME relay DME relay
14 A Supply Motor-driven throttle actuator Motor-driven throttle actuator
15 E Signal Motor-driven throttle actuator Motor-driven throttle actuator
16 E Signal Motor-driven throttle actuator Motor-driven throttle actuator
17 E Signal Intake air temperature/boost pressure sensor Intake air temperature/boost pressure sensor
18 -- Not used
19 E Signal Double knock sensor Double knock sensor
20 E Signal Double knock sensor Double knock sensor
21 -- Not used
22 -- Not used
23 A Signal, fuel tank vent valve Fuel tank vent valve
24 -- Not used
25 -- Not used
26 -- Not used
27 -- Not used
28 -- Not used
29 E Signal Crankshaft sensor Crankshaft sensor
30 M Ground Crankshaft sensor Crankshaft sensor
31 A Supply Intake manifold pressure sensor Intake manifold pressure sensor
32 M Ground Intake manifold pressure sensor Intake manifold pressure sensor
33 E Signal Intake manifold pressure sensor Intake manifold pressure sensor
34 E Signal Low pressure fuel sensor Low pressure fuel sensor
35 E/A BSD signal Connector BSD signal
36 E Signal Motor-driven throttle actuator Motor-driven throttle actuator
37 E Signal Motor-driven throttle actuator Motor-driven throttle actuator
38 M Ground Motor-driven throttle actuator Motor-driven throttle actuator
39 -- Not used
40 -- Not used
41 E Signal Double knock sensor Double knock sensor
42 E Signal Double knock sensor Double knock sensor
43 -- Not used
44 -- Not used
Pin assignments at plug connector X60006
1 A Positive activation Injection system, cylinder 1
2 A Positive activation Injection system, cylinder 2
3 A Positive activation Injection system, cylinder 3
4 A Positive activation Injection system, cylinder 4
5 A Positive activation Injection system, cylinder 5
6 A Positive activation Injection system, cylinder 6
7 A Negative activation Injection system, cylinder 1
8 A Negative activation Injection system, cylinder 2
9 A Negative activation Injection system, cylinder 3
10 A Negative activation Injection system, cylinder 4
11 A Negative activation Injection system, cylinder 5
12 A Negative activation Injection system, cylinder 6
Pin assignments at plug connector X60007
1 -- Not used
2 -- Not used
3 -- Not used
4 E Signal, coolant temperature Engine coolant temperature sensor
5 A Activation VANOS solenoid valve, intake VANOS solenoid valve, intake
6 -- Not used
7 A Activation Wastegate valve
8 M Ground Rail pressure sensor Rail pressure sensor
9 E Signal Rail pressure sensor Rail pressure sensor
10 A Supply Rail pressure sensor Rail pressure sensor
11 E Signal Camshaft sensor I Camshaft sensor I
12 E Signal Camshaft sensor II Camshaft sensor II
13 E Signal, oil pressure switch Oil pressure switch
14 A Activation Wastegate valve 2
15 -- Not used
16 -- Not used
17 M Ground Engine coolant temperature sensor Engine coolant temperature sensor
18 A Activation VANOS solenoid valve, exhaust VANOS solenoid valve, exhaust
19 E Signal Characteristic map thermostat Characteristic map thermostat
20 -- Not used
21 -- Not used
22 -- Not used
23 -- Not used
24 M Ground Camshaft sensor I Camshaft sensor I
25 M Ground Camshaft sensor II Camshaft sensor II
26 E/A BSD signal Electric coolant pump
