Bad issue
Ez096
10
Hi everyone
I have bmw e60 2008 N52 engine,
front headlights And taillights stay on when car off , I was change relay for terminal 15 and light module but issue still ,
I have 3 faults in cas module
1. A0BE terminal 15 output 1
2 .A0BF terminal 15 output 2
3 .A0CO terminal 15 output 3
And for fault in light module LM
9CAB one terminal 15 missing
Any idea
Thanks in advance
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
A seems time to be looking for a replacement light module?
Do the lights stay on only for a couple mins or would they stay on until the battery died?
NoQuarter
1,662
1,066
Indiana, USA
Try looking for a used Light Module I think.
I have never seen anyone with a problem where the lights won't turn off.
wireboy
Ram
I was change light module from car used
And pls check inbox
Try unplugging the level sensors. I have seen the sensors short out causing feedback into the light module which keeps the lights on.
Ez096
10
The car not xenon headlights and I think it's not has level sensor
Jramirez97
I have the same problem, did you solve your problem? I have the same codes and the same lights on all the time, they told me that I have to change or repair the CAS module but I don't know if it will be solved. Thank you
tahirkass
Did you manage to resolve the issue ? I have just 9CAB code in LM but no other faults including in the CAS, mine only the brake lights stay on with ignition off, when ignition on or ACC, everything is normal . . .
