W
Datalog Any problems with log?
WayEast
11
Louisiana
2014 Z4 35i
I am asking because on my first run at WOT after I programmed to MHD 2+ I received a CEL code 29cd. I cleared the code and it has not came back on other runs. Just marking sure everything looked ok with the log.
Slowagon54
207
96
29cd indicates a missfire. Keep an eye on it and try to use the highest possible octane fuel only.
EDIT: What Index do the fuel injectors have?
AJN55
Minneapolis
2011 335i xDrive
Sometimes you can get misfires under high boost if your plugs aren’t gapped a little tighter. 0.022 tends to be what most people run with a more aggressive tune. What are yours gapped at?
WayEast
11
Louisiana
2014 Z4 35i
Mine are gapped at .022. Even tried going back to new bosh plugs still same code. Tried different octane settings, swapped coils, plugs, and injectors same code. If I run at MHD stage 2 no issues.
AJN55
Minneapolis
2011 335i xDrive
That’s definitely a mystery, maybe a pro-tuner could figure it out. If you’ve tried all of those things and nothing solves it, it’s so hard to tell.
