A few questions on self tuning
MoreBoost
372
146
Hi Everyone.
I'm planning to do some self tuning. Have bought various tunes over the years.
Car is IJE0S, DCT, 335i with 19T turbos, catless DP and exhaust, 3.5bar tmap, 535lpfp, inlets, outlets, HD Race FMIC. Was running a JB4 and Meth injection. BL harness, R8 coils.
I've been an N54 owner for a long time. My car has been off the road for quite a while. Bad injector(s) I suspected.
Now I've installed 6 new index 12s, which are coded with INPA. More work is necessary on the car before it's road worthy.
I put on self made tune. The car is misfiring, usually cylinders 2, 5 and 6 on cold start.
I just wanted a basic flash that is drivable. I already made the 3 cell change for the TMAP and selected BL Coils.
I need to rescale load, given the TMAP. Think I understand how to do that. Wouldn't be driving anything but slowly at this point anyway.
My questions are. Given the BL coils, do I need to do anything in any tables, given I've checked that option when writing the flash to the car?
Secondly. Do I need to do anything given the stronger lpfp, for example on the fuel start table?
At the moment I'm targeting 1.00 to 1.05 fuel scalars. Fuel here is 5% ethanol. I am just creating a pump fuel tune at the moment. Low boost, low timing.
I've ordered new ngk spark plugs. Current ones are gapped to 0.020" but a bit fouled so are being replaced. Coils seem ok but I may test their resistance soon.
I will probably pull the injectors again to see that they look ok.
I was getting a 2ABD DME: Boost-pressure sensor, overrun so I wonder if my TMAP may have gone bad?
Any advice would be greatly appreciated. Thank you.
889
Have you read this thread about needing to modify the R8 coils for n54?
If you haven't modded them, it could be the reason for your misfires.
1,674
Ditch the R8 coils, now that the B58 coils are compatible there's no reason to use anything else, stock to stock or B58.
As for tuning. I see you have a DCT. This is likely your other complicating factor. You need to read the DCT tuning threads and account for those tables and how they effect what you're doing in load/wgdc especially with throttle limits. It's just not straight forward like manual tuning.
MoreBoost
372
146
Yes. I've been running the coils very soon after they first came out. A number of years but thank you for checking. šŸ‘
MoreBoost
372
146
Ah yes. DCT is different. Oh joy! :)
Well I suspect my TMAP may be bad so I'll replace that and throw in new gapped spark plugs first.
Fingers crossed it starts and idles without misfires.
The only difference with the DCT is that it's sensitive to torque reporting. All auto transmissions are but the slushboxes are more tolerant to the clutch slip you get when you under report.
As long as you proportionally increase the load as you scale the tmap you'll be ok. It's not ideal, but it's the only way to target above 22psi.
Ideally you want to scale the tmap as little as possible. So only scale as far as you need rather than going full scale on the 3.5bar and only using 25psi of it.
MoreBoost
372
146
Hey thanks Carabuser.
That's very useful info.
At first I will just be creating a tune for regular driving. Probably no more than 16 psi.
Until I'm happy the car is happy and healthy.
I'm hoping my misfires on startup will be remedied by the new plugs and TMAP sensor. Feels like I can't even get past the start line yet.
I also have an electrical issue between the DME and the siren/alarm draining the battery. I think the issue is a contact damaged by an LED I swapped for a bulb in the overhead lights.
It'll be nice to have he car back driving again and then finally push some real power. I have XHP stage 3 for the DCT but I assume I still need to report torque as high as possible without hitting limiters.
Misfire unlikely to be just plugs unless they are fully broken. Like already mentioned the coils might have problems.
You don't really want to to report torque higher, just keep it as close as possible to the stock reporting.
Reactions: MoreBoost
MoreBoost
372
146
I tried swapping the 2.5 bar TMAP back in until my new 3.5 arrives.
Switched the map back for 2 cell map.
Got the misfires again on cold start and these codes
29CC - DME: Combustion misfires, several cylinders
29D1 - DME: Combustion misfires, cylinder 5
29D2 - DME: Combustion misfires, cylinder 6
2D2E - DME: throttle-valve angle - intake manifold vacuum, correlation
2F15 - DME: Charge air temperature
3100 - DME: Boost-Pressure control, deactivation
Any advice would be great. I will try to calibrate the throttle body, holding it down on full for 30+ seconds.
I have not yet tried swapping coils.
2f15 and 2d2e are related to bad tmap. Make sure you have the 3 wires in the right order. The pinout for the 3.5bar and 2.5bar are different.
MoreBoost
372
146
I have the burger tuning adapter so I removed that. Put in my original 2.5 bar tmap. It's quite old so may be bad also.
